.NET
Hans530
Message 1 of 12 (2,576 Views)
SendStringToExecute
2576 Views, 11 Replies
03-19-2012 07:48 AM
 Hi Everybody
When the code below are executed the line, drawing the line are executed after the rest of the code,
that is the msgboxes are displayed before the line are drawn in Acad_Window.
what should be done to display the  msgboxes before the line, as the order in the code indicates
Hope someone has an explanation and solution to this
With Regards
HansP
Application.DocumentManager.MdiActiveDocument.SendStringToExecute("line_
1800,2001600,3000 ", True, False, True)
MsgBox("DWG Saved")
dwgPath = ThisDrawing.GetVariable("DWGPREFIX")
dwgName = ThisDrawing.GetVariable("DWGNAME")
Dim thisDwg AsString = dwgPath + dwgName
MsgBox(thisDwg)
norman.yuan
Message 2 of 12 (2,572 Views)
Re: SendStringToExecute
03-19-2012 08:14 AM in reply to: Hans530
What you should do is to use the .NET API to
  • Start a Transaction
  • Construct a Line object, such as:
  Dim l as Line=New Line
  Line.StartPoint=New Point3d(....)
  Line.EndPoint=New Point3d(...)
  • Set the line's properties as needed
  • Append the line to targeting space (Model or layout)
  • Commit the transaction
You can create a command method to cover all the steps aforemention, and then use SendStringToExecution() method as one call.
If the intention is to use all Acad existing/built-in commands, use AutoCAD script would do in most cases.
Hans530
Message 3 of 12 (2,571 Views)
03-19-2012 08:23 AM in reply to: Hans530
Thank you for your quick responce
The line worked fine, but how to do with a zoom command.
Hans P
ranjith0326
Message 4 of 12 (2,535 Views)
03-19-2012 10:05 PM in reply to: Hans530
Try with below one
Application.DocumentManager.MdiActiveDocument.SendStringToExecute("zoom e ", True, False, True)
R.Ranjith
Moderator
Alexander.Rivilis
Message 5 of 12 (2,529 Views)
03-19-2012 11:30 PM in reply to: Hans530
http://forums.autodesk.com/t5/NET/ZoomWindow-and-ZoomScale/m-p/3249340#M26321
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Hans530
Message 6 of 12 (2,519 Views)
03-20-2012 03:57 AM in reply to: Alexander.Rivilis
I do not know anything about C# so, I translated the ZoomExtents like this. It compiled OK but there was a runtime error complaining about the BindingFlags. As I don’t know any C# and as it seems not enough VB either to translate that part of the code where several BindingFlags are listid. I must ask for further help with that part
Thanks in advance Hans P
public static void ZoomExtents()
        object acad = Application.AcadApplication;
        acad.GetType().InvokeMember("ZoomExtents", BindingFlags.DeclaredOnly | BindingFlags.Public |
             BindingFlags.Instance | BindingFlags.InvokeMethod, null, acad, null);
Public Sub ZoomExtents()
Dim acad As Object = Application.AcadApplication
acad.GetType().InvokeMember("ZoomExtents",BindingFlags.DeclaredOnly, Nothing, acad, Nothing)
End Sub
Moderator
Alexander.Rivilis
Message 7 of 12 (2,517 Views)
03-20-2012 03:59 AM in reply to: Hans530
Imports System.Reflection
Hans530
Message 8 of 12 (2,508 Views)
03-20-2012 04:37 AM in reply to: Alexander.Rivilis
I had that one without that it wouldn't compile
But is the row
translated ok from C#
 Hans P
Moderator
Alexander.Rivilis
Message 9 of 12 (2,506 Views)
03-20-2012 04:44 AM in reply to: Hans530
acad.GetType().InvokeMember("ZoomExtents",BindingFlags.InvokeMethod, Nothing, acad, Nothing)
_gile
Message 10 of 12 (2,479 Views)
03-20-2012 03:08 PM in reply to: Alexander.Rivilis
While using Reflection/Late binding, we can use some (extension) methods to make the code more readable than the :
GetType().InvokeMember(...)
With C# and Framework 3.5 or upper, we can write some extension methods so that the upper expression to ma make zoom extents become:
acad.Invoke("ZoomExtents");
or, to set the cursor size to 10:
acad.Get("Preferences").Get("Display").Set("CursorSize", 10);
public static class LateBinding
	public static object Get(this object obj, string propName, params object[] parameter)
		return obj.GetType().InvokeMember(propName, BindingFlags.GetProperty, null, obj, parameter);
	public static void Set(this object obj, string propName, params object[] parameter)
		obj.GetType().InvokeMember(propName, BindingFlags.SetProperty, null, obj, parameter);
	public static object Invoke(this object obj, string methName, params object[] parameter)
		return obj.GetType().InvokeMember(methName, BindingFlags.InvokeMethod, null, obj, parameter);
With F#, it's really easy to extend any Type, but ther's no way (AFAIK) to use optional parameters (as with params or ParamArray), but creating an array is so simple.
The zoom extents:
acad.invoke("ZoomExtents", null) |> ignore
The cursor to 10:
let size = acad.get("Preferences", null).get("Display", null).set("CursorSize", [| 10 |])
type Object with
    member x.get(propName, parameter) =
        x.GetType().InvokeMember(propName, BindingFlags.GetProperty, null, x, parameter)
    member x.set(propName, parameter) =
        x.GetType().InvokeMember(propName, BindingFlags.SetProperty, null, x, parameter)
        |> ignore
    member x.invoke (propName, parameter) =
        x.GetType().InvokeMember(propName, BindingFlags.InvokeMethod, null, x, parameter)
VB do not allow to use extension methods with the Object Type, but we can define methods so that late binding expressions look like the vlax-get, vlax-put, and vlax,invoke LISP functions.
The zoom extents:
Invoke(acad, "ZoomExtents")
The cursor to 10:
SetProperty(GetProperty(GetProperty(acad, "Preferences"), "Display"), "CursorSize", 10)
Module LateBindingExtensions
    Public Function GetProperty(ByVal obj As Object, ByVal propName As String, ByVal ParamArray parameter As Object()) As Object
        Return obj.GetType().InvokeMember(propName, BindingFlags.GetProperty, Nothing, obj, parameter)
    End Function
    Public Sub SetProperty(ByVal obj As Object, ByVal propName As String, ByVal ParamArray parameter As Object())
        obj.GetType().InvokeMember(propName, BindingFlags.SetProperty, Nothing, obj, parameter)
    End Sub
    Public Function Invoke(ByVal obj As Object, ByVal methName As String, ByVal ParamArray parameter As Object()) As Object
        Return obj.GetType().InvokeMember(methName, BindingFlags.InvokeMethod, Nothing, obj, parameter)
    End Function
End Module
Gilles Chanteau
