.NET
SendCommand
11 REPLIES 11
Message 1 of 12
raulpa
1919 Views, 11 Replies
SendCommand
Hi:
Can somebody please tell me if it is possible to Synchronously execute a command sent via SendCommand while using the COM/ActiveX interface in VB 2005? I know I can do this in VBA (in my particular application the commands executed via SendCommand are always complete and the program never needs to wait for user data), but I was hoping I could do the same using VB 2005. Unfortunately, so far I have not been able to do that. In the example below the SendCommand is executed after the file has been saved and I want it to execute before the file is saved. Can somebody please tell me if it is even possible to do what I want to do?
Any ideas would be greatly appreciated,
Raul
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.Interop
Imports Autodesk.AutoCAD.Interop.Common
Imports System.IO
Public Class ClsTest
>CommandMethod("Test")> _
Public Sub Test()
Dim OutputPath As String = "c:\Test\dwg"
Dim ObjAcad As AcadApplication
Dim ThisDrawing As AcadDocument
Dim Obj As Acad3DSolid
Dim ZeroOrgin() As Double = {0, 0, 0}
Dim Width as Double = 2
Dim Depth as Double = 4
Dim Length as Double = 8
Directory.Delete(OutputPath, True)
Directory.CreateDirectory(OutputPath)
ObjAcad = DirectCast(GetObject(, "AutoCAD.Application.17"), AcadApplication)
ObjAcad.Visible = True
ThisDrawing = ObjAcad.ActiveDocument
Obj = ThisDrawing.ModelSpace.AddBox(ZeroOrgin, Width, Depth, Length)
ThisDrawing.SendCommand("_zoom" & vbCr & "e" & vbCr)
' I was hoping the Do Loop below would be the answer to my problem,
' but IsQuiescent is never True and as a result the program hangs.
' Without the Do Loop, the SendCommand is not executed until after
' the drawing is saved, which is not what I want. Any ideas how to
' solve this problem?
Do Until ObjAcad.GetAcadState.IsQuiescent = True
Loop
ThisDrawing.SaveAs(OutputPath & "\Test.dwg")
End Sub
End Class
11 REPLIES 11
Message 2 of 12
in reply to: raulpa
Break the sequence up into parts and then use AutoLISP or ARX to control the
sequencing.
Message 3 of 12
in reply to: raulpa
I use any thing as this
I wait that this can help you
tp
Imports AcAp = Autodesk.AutoCAD.ApplicationServices
Imports AcDb = Autodesk.AutoCAD.DatabaseServices
Imports AcRx = Autodesk.AutoCAD.Runtime
Public Module Module1
_
Public Sub Teste()
Dim doc As AcAp.Document =
AcAp.Application.DocumentManager.MdiActiveDocument
AddHandlers()
doc.SendStringToExecute("_zoom" & vbCr & "e" & vbCr, True, False,
False)
End Sub
Private m_Command As String = Nothing
Sub AddHandlers()
Dim d As AcAp.Document =
AddHandler d.CommandWillStart, AddressOf CommandWillStart
AddHandler d.CommandEnded, AddressOf CommandEnded
AddHandler d.CommandFailed, AddressOf CommandFailed
AddHandler d.CommandCancelled, AddressOf CommandCancelled
End Sub
Sub RemoveHandlers()
RemoveHandler d.CommandWillStart, AddressOf CommandWillStart
RemoveHandler d.CommandEnded, AddressOf CommandEnded
RemoveHandler d.CommandFailed, AddressOf CommandFailed
RemoveHandler d.CommandCancelled, AddressOf CommandCancelled
m_Command = Nothing
End Sub
Sub CommandWillStart(ByVal sender As Object, ByVal e As
Autodesk.AutoCAD.ApplicationServices.CommandEventArgs)
If m_Command Is Nothing Then m_Command = e.GlobalCommandName
End Sub
Sub CommandEnded(ByVal sender As Object, ByVal e As
If e.GlobalCommandName = m_Command Then
Dim db As AcDb.Database =
AcDb.HostApplicationServices.WorkingDatabase()
db.SaveAs("C:\Teste.dwg", AcDb.DwgVersion.Current)
RemoveHandlers()
End If
End Sub
Sub CommandCancelled(ByVal sender As Object, ByVal e As
RemoveHandlers()
End Sub
Sub CommandFailed(ByVal sender As Object, ByVal e As
RemoveHandlers()
End Sub
End Module
escreveu na mensagem
news:5372117@discussion.autodesk.com...
Hi:
commands
to
below
even
Raul
Imports System.IO
Public Sub Test()
AcadApplication)
Loop
End Sub
End Class
I'm protected by SpamBrave
http://www.spambrave.com/
Message 4 of 12
raulpa
in reply to: raulpa
James, TP:
Thank you very much for both of your replies. I implemented what I thought you suggested. As you can see from the code below, I created a ClsSendCommand class which contains the MyZoomExtend Sub. The MyZoomExtend Sub is nothing more than a call to the SendStringToExecute Method. Since this behaves the same way as the original code (the zoom extend does not happen until after the Save), I assume I must have misunderstood your suggestion. Could you please tell me where I went wrong?
Thanks again for your help,
Raul
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Public Class ClsSendCommand
Public Sub MyZoomExtend()
' I am aware that the Zoom extend command is probably not a good candidate
' for using either the SendCommand or SendStringToExecute method because the
' Zoom command is already exposed by the COM/ActiveX interface. However,
' this was the simplest example I could find. In reality, I need to use the
' vplayer and solprof commands, which I don't believe are exposed by the
' COM/ActiveX interface.
Application.DocumentManager.MdiActiveDocument.SendStringToExecute("_zoom" & vbCr & "e" & vbCr, True, False, False)
End Sub
End Class
Imports System.IO
Public Sub Test()
Dim Width As Double = 2
Dim Depth As Double = 4
Dim Length As Double = 8
Dim SendCommand As New ClsSendCommand
' The problem I am having is that the line below does not get executed
' until after the SaveAs
SendCommand.MyZoomExtend()
End Sub
End Class
Message 5 of 12
in reply to: raulpa
you need to call Sub AddHandlers().
I not use AutoCAD.Interop.
it forgives my English
tp
' ========================== START CODE ============================
_
Public Sub Teste()
' First call AddHandlers to inicitiate events
AddHandlers()
False)
End Sub
Sub AddHandlers()
End Sub
m_Command = Nothing
End Sub
End Sub
=AcDb.HostApplicationServices.WorkingDatabase()
RemoveHandlers()
End If
End Sub
RemoveHandlers()
End Sub
RemoveHandlers()
End Sub
End Module
' ========================== END CODE ============================
Message 6 of 12
in reply to: raulpa
http://www.caddzone.com/CommandLine.cs
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
wrote in message news:5372117@discussion.autodesk.com...
Hi:
Raul
Imports System.IO
Public Sub Test()
Loop
End Sub
End Class
Message 7 of 12
raulpa
in reply to: raulpa
All:
Thank you so much for taking the time to respond. I finally got my problem solved. It looks like the problem was with the way I was using the CommandMethod. Here is the way I was originally using it (notice that I replaced the "<" symbol with ">" just to avoid the online editor from suppressing the entire CommandMethod line):
All I needed to do is this instead:
>CommandMethod("Test",CommandFlags.Session)> _
After adding the CommandFlags.Session everything works as expected (i.e. the SendCommands and rest of VB.Net code execute in the order in which they are typed).
Raul
Message 8 of 12
jason.brenton
in reply to: raulpa
I see many examples of point parameters on commands, but what about selected/passed objects like polylines or blocks?
How are those commands formatted? maybe with the ObjectIds?
Message 9 of 12
in reply to: raulpa
This is a a topic for the VBA newsgroup.
AcadXTabs: MDI Document Tabs for AutoCAD 2008
Supporting AutoCAD 2000 through 2008
wrote in message news:5841893@discussion.autodesk.com...
Message 10 of 12
jason.brenton
in reply to: raulpa
why? i am calling it from a .net dll, not vba
Message 11 of 12
in reply to: raulpa
wrote in message
You are calling what from a .NET dll?
A managed ObjectARX API, or an ActiveX API?
We mainly discuss using the managed ObjectARX API here, not the VBA/ActiveX API.
Your question about SendCommand() has the same answer regardless of what programming langauge you're calling it from, and has been asked and answered dozens of times in the VBA newsgroup (hint: search that newsgroup on the keyword "handent").
It may be called the VBA newsgroup, but it would more accurately be called the ActiveX newsgroup, because many topics about that API are discussed there, including those related to using it from standalone VB6 (not VBA); Delphi; C#; and other ActiveX-enabled development tools.
Message 12 of 12
jason.brenton
in reply to: raulpa
well that is more clear of a response, as most likely SendStringToExecute uses similar style. either can be found. I'll check.
”Boost
