I am trying to write a command to autoselect all text with a specific textstylename and change the color of it.
This is my code at this moment:
<CommandMethod("TK")> _
Public Sub Tekstkleur()
'' Get the current document and database
Dim doc As Document = Application.DocumentManager.MdiActiveDocument
Dim db As Database = HostApplicationServices.WorkingDatabase
Dim ed As Editor = DocumentManager.MdiActiveDocument.Editor
'' Start a transaction
Using acTrans As Transaction = db.TransactionManager.StartTransaction()
Dim WFO1(0) As TypedValue
'' Create a TypedValue array to define the filter criteria
WFO1.SetValue(New TypedValue(DxfCode.TextStyleName, "WFO 1.5"), 0)
'' Assign the filter criteria to a SelectionFilter object
Dim selectiefilter As New SelectionFilter(WFO1)
'' Request for objects to be selected in the drawing area
Dim acSSPrompt As PromptSelectionResult = ed.GetSelection(selectiefilter)
'' If the prompt status is OK, objects were selected
If acSSPrompt.Status = PromptStatus.OK Then
Dim acSSet As SelectionSet = acSSPrompt.Value
'' Step through the objects in the selection set
For Each acSSObj As SelectedObject In acSSet
'' Check to make sure a valid SelectedObject object was returned
If Not IsDBNull(acSSObj) Then
'' Open the selected object for write
Dim acEnt As Entity = acTrans.GetObject(acSSObj.ObjectId, _
OpenMode.ForWrite)
If Not IsDBNull(acEnt) Then
'' Change the object's color to Green
acEnt.ColorIndex = 3
Next
'' Save the new object to the database
acTrans.Commit()
'' Dispose of the transaction
End Using
End Sub
When i debug the command i can change the color but it doesn't work automatically because when i'm at "Dim acSSPrompt As PromptSelectionResult = ed.GetSelection(selectiefilter)" It asks me to select objects in Autocad. When i select several objects, it only selects text with stylename: "WFO 1.5" so that works. But i want autocad to automatically select all text with stylename: "WFO 1.5".
Can someone help me out with this?
If I properly understand your question, replace
into
ed.SelectAll(selectiefilter)
gsktry
