.NET
SelectionFilter on Blockreference XData
3 REPLIES 3
591 Views, 3 Replies
Hi.
I'm trying to use a SelectionFilter on BlockReference XData value.
But I get no hits, it works fine with Lines and Polylines that has the same
kind of XData.
Is it a bug or do I have to define my SelectionFilter differently when
working with BlockReference?
Here is a part of the code :
TypedValue[] flt = new TypedValue[]
new TypedValue(-4, " new TypedValue(-4, " new TypedValue(8, "POLYLINE_LAYER"),
new TypedValue(1001, "Object_Id"),
new TypedValue(1000, "166448"),
new TypedValue(-4, "AND>"),
new TypedValue(-4, " new TypedValue(8, "BLOCKREFERENCE_LAYER"),
new TypedValue(1000, "500077"),
new TypedValue(-4, "OR>")
Best regards
Peter
3 REPLIES 3
Hi. The only XData group you can filter on
is the 1001 (appid).
You can filter on your appid, and then manually
locate what you need in the resulting selection.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2008
Supporting AutoCAD 2000 through 2008
http://www.acadxtabs.com
"PeterG" wrote in message news:5549683@discussion.autodesk.com...
Hi.
kind of XData.
Best regards
Peter
Thanks Tony.
But why is that?
It works fine with Lines and Polylines.
Is it a bug or is it just the way it is?
"Tony Tanzillo" wrote in message
news:5550054@discussion.autodesk.com...
Hi.
kind of XData.
Best regards
Peter
mapaquin
I am having exactly the same issue.  I too am curious to as why this is not possible specifically with block references and works with any other type of entity?
Marc
”Boost
