.NET
sist111
457 Views, 6 Replies
selection
Can anyone advice how to get selection (highlighted with grips) to work with using AutoCad commands the same way as I selected it on screen?
6 REPLIES 6
in reply to: sist111
From a registered command handler, add the CommandFlags.UsePickSet flag to
the CommandMethod attribute, and the current selection will be used when you
call any Editor method that prompts for multiple objects, or when you call
the Editor's SelectImplied() method.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6296504@discussion.autodesk.com...
sist111
Thank you, Tony Tanzillo, but I ment something different. I ment that class is terminated, and left only three of us: AutoCad, me and selection.
Now when i use:
editor.SetImpliedSelection(objectIds);
promptSelectionResult = editor.GetSelection();
I have only command string message "[number] found" and can use "select -> previous" command (or "previous" within command). But I'd like the result as command QuickSelect has, for example - selection with blue grips and highlited.
add the follow line below your promptSelectionResult to show your grips.
editor.SetImpliedSelection(promptSelectionResult.Value);
wrote in message news:6297071@discussion.autodesk.com...
Now when i use:
highlited.
sist111
promptSelectionResult.Value is SelectionSet, SetImpliedSelection needs ObjectId[].
Add the CommandFlags.Redraw flag in your CommandMethod attribute, and call
SetImpliedSelection() and pass it the array of objectids that you want to
leave selected.
Now when i use:
highlited.
The code at the following link shows how to leave objects selected when a
custom command ends:
http://www.caddzone.com/BlockExplodeHelper.cs
wrote in message news:6297330@discussion.autodesk.com...
ObjectId[].
”Boost
