.NET
.NET
mgorecki
Message 1 of 11 (1,046 Views)
Selection Set Selects Circles and Blocks, How to Tell Them Apart
1046 Views, 10 Replies
04-26-2011 09:53 AM
Hi, ok I know this is a newbie question, but I've looked through this site and other sources before just plain asking the people who would know.
I have a selection set filter set to get only circles and blocks (INSERT).  Then it gets to a part of the code that says for each object in my group of objects... do something.
The first few lines of the "do something" are:
For Each bgaObjID In bgaObjIDs
Dim myBlockRef As DatabaseServices.BlockReference
myBlockRef = bgaObjID.GetObject(DatabaseServices.OpenMode.ForRead)
If it's a block, then it's just fine.  If it's a circle, it crashes.  Obviously circles aren't blocks and that's why it crashes.  I'm trying to set up an If..Then statement so that blocks use one set of statements and circles use another.  I've looked at the values for the objectID, but cannot tell how to determine if it's a block ref or a circle.
If it's a circle, I would use:
Dim tempCir As Circle = TryCast(bgaObjID.GetObject(DatabaseServices.OpenMode.ForRead), Circle)
Can someone help me out on this?
Mark
I just checked the ObjectArx2008 docs and the ObjectClass was not an available property in the 2008 managed API. So, no, there's nothing wrong with your setup.
Valued Mentor
Jeffrey_H
Message 2 of 11 (1,039 Views)
Re: Selection Set Selects Circles and Blocks, How to Tell Them Apart
04-26-2011 10:27 AM in reply to: mgorecki
If you want to use TryCast then if it fails it has to be a block reference
            Dim objIdColl As New ObjectIdCollection
            For Each objId As ObjectId In objIdColl
                ''If performance is a issue this is faster
                If objId.ObjectClass.Name = "AcDbCircle" Then
                ElseIf objId.ObjectClass.Name = "AcDbBlockReference" Then
                End If
                If objId.ObjectClass.DxfName = "CIRCLE" Then
                ElseIf objId.ObjectClass.DxfName = "INSERT" Then
                End If
                Dim ent As Entity = objId.GetObject(OpenMode.ForRead)
                If TypeOf ent Is Circle Then
                ElseIf TypeOf ent Is BlockReference Then
                End If
                Dim cir As Circle = TryCast(objId.GetObject(OpenMode.ForRead), Circle)
                If cir IsNot Nothing Then
                Else
                    ''If you onle have circles and blockreferences and it is not a circle then is a blockreference
                End If
            Next
You can also find your answers @ TheSwamp
chiefbraincloud
Message 3 of 11 (1,024 Views)
04-26-2011 11:46 AM in reply to: mgorecki
This way is better, because you are not using a runtime exception as a test.
    If bgaObjID.ObjectClass.Name = "AcDbBlockReference" then
    Elseif bgaObjID.ObjectClass.Name = "AcDbCircle" then
    end if
next
Sorry Jeffrey, I kind of blasted over your post quickly, and only saw the TryCast.  Didn't catch that you had included the ObjectClass property at the beginning.
mgorecki
Message 4 of 11 (1,011 Views)
04-26-2011 03:41 PM in reply to: chiefbraincloud
Hello and thanks for the replys.
Here is what I have dimmed:
Dim myDWG As ApplicationServices.Document
Dim myEd As EditorInput.Editor
Dim myPSR As EditorInput.PromptSelectionResult
Dim bgaSelectionSet As EditorInput.SelectionSet
Dim myTransMan As DatabaseServices.TransactionManager
Dim myTrans As DatabaseServices.Transaction
Dim myBT As DatabaseServices.BlockTable
Dim myBTR As DatabaseServices.BlockTableRecord
Dim bgaObjIDs As New ObjectIdCollection
Dim bgaObjID As DatabaseServices.ObjectId
myDWG = ApplicationServices.Application.DocumentManager.MdiActiveDocument
myEd = myDWG.Editor
myPSR = myEd.SelectWindow(ssWindowPnt1, ssWindowPnt2, bgaSSFilter)
If Not IsNothing(myPSR.Value) Then
  myTransMan = myDWG.TransactionManager
  myTrans = myTransMan.StartTransaction
  bgaSelectionSet = myPSR.Value
  bgaObjIDs = New DatabaseServices.ObjectIdCollection(bgaSelectionSet.GetObjectIds)
  For Each bgaObjID As ObjectId In bgaObjIDs
    If bgaObjID.ObjectClass.Name = "AcDbBlockReference" Then
      ballCenter = myBlockRef.Position
    End If
I get an error saying "ObjectClass is not a member of 'Autodesk.AutoCAD.DatabaseServises.ObjectId'."
Any advice?
Mark
chiefbraincloud
Message 5 of 11 (1,003 Views)
04-26-2011 04:09 PM in reply to: mgorecki
I use the ObjectClass property lots of times in my code, and it has been there as long as I can remember.  What version of AutoCAD are you using?
For what it is worth, the reason I use the ObjectClass property a lot is that it allows you to type-test the object without having to open it in a transaction.  Let's say you are looping the contents of a BlockTableRecord looking for AttributeDefinitions.  That allows you to skip over the objects that are not AttributeDefinitions without having to open them.
That said, you are looping a selection which has been filtered, and apparently opening every BlockReference and every Circle that you have in your selection.  Since you know that everything in your selection is a BlockReference or a Circle, the Third approach suggested by Jeffrey has (almost) no overhead cost associated with it.
dim ent as Entity = myTrans.GetObject(bgaObjID, OpenMode.For(Read or Write))
If TypeOf ent is BlockReference then
     dim bref as BlockReference = ent
else  'you could say ElseIf TypeOf ent is Circle, but it would be redundant because there are only two possibilities
     dim circ as Circle = ent
End If
Valued Mentor
Jeffrey_H
Message 6 of 11 (995 Views)
04-26-2011 05:48 PM in reply to: chiefbraincloud
So your code is kinda like me repeating what Chief just said,
as in it is testing if it is a circle or blockreference so you can then test if it is a circle or blockreference.
Remember that after a little time you will figure out how use the docs and MGDDbg to find what you after but most important pay attention to post made by guys like ChiefBrainCloud where you pick up good coding and software design.
chiefbraincloud
Message 7 of 11 (992 Views)
04-26-2011 06:12 PM in reply to: Jeffrey_H
Don't give me too much credit, It'll go to my head!  I was not educated as a programmer, I am an engineer.  But I have been tinkering with Basic and later visual Basic for a very (very) long time.  My first Basic program was written for the Atari 800 back in ~1984, when I used to have to store my work on a cassette tape, before even 5 1/4" Low Density floppy disks.
I have only carried the Title of Programmer (now Software Developer) since 2005.
As far as the .NET framework Do's and Don'ts, I'll happily credit Kean Walmsley's blog for bringing me out of the VB6 dark ages.
mgorecki
Message 8 of 11 (975 Views)
04-27-2011 07:28 AM in reply to: mgorecki
Thank you both for all of the information.  I'm using AutoCad 2008.  I bought a book on VB.Net for AutoCad a while ago and have used it quite a bit.  I also read these forums and try to learn from what other people go through.  I really appreciate that you take time out to help me.
Mark
mgorecki
Message 9 of 11 (970 Views)
04-27-2011 08:23 AM in reply to: mgorecki
I did some reading on "ObjectClass" and I wanted to try using it in just some test code, but I still get the error message:  "'ObjectClass' is not a member of 'Autodesk.AutoCAD.DatabaseServices.ObjectId'."
I'm using AutoCad 2008 with Visual Studio 2005.  Could there be something wrong with my setuip?  Is there something I should look for in particular?
Mark
Jeff_M
Message 10 of 11 (952 Views)
04-27-2011 07:50 PM in reply to: mgorecki
