.NET
Member
fred.schippers
Message 1 of 6 (246 Views)
Selection of multiple nested entities
246 Views, 5 Replies
01-11-2013 01:46 AM
There are blocks in the drawing, each containing several nested entities. Need a command which would find all the nested entities which got into the selection area provided by user (not necessary to select entities, just get the ids). GetNestedEntity() does what I need but for a single entity only.
Selection of 'Trim' command does exactly what I need. How could I achieve the same behaviour?
Thank you.
Moderator
Alexander.Rivilis
Message 2 of 6 (230 Views)
Re: Selection of multiple nested entities
01-11-2013 04:46 AM in reply to: fred.schippers
fred.schippers wrote:
... not necessary to select entities, just get the ids ...
It is easy to iterate BlockTableRecode and get all ObjectId's of subentities (except constant AttributeDefinition)
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Member
fred.schippers
Message 3 of 6 (227 Views)
01-11-2013 04:48 AM in reply to: Alexander.Rivilis
I don't need all subentities, just those selected by user.
Moderator
Alexander.Rivilis
Message 4 of 6 (224 Views)
01-11-2013 04:53 AM in reply to: fred.schippers
Ok. What about Editor.GetSelection with argument PromptSelectionOptions with properties AllowSubSelections and ForceSubSelections equal true?
Member
fred.schippers
Message 5 of 6 (221 Views)
01-11-2013 04:59 AM in reply to: Alexander.Rivilis
Doesn't work. Even blocks can not be selected in this case.
Have found similar question here, but it was not answered :smileysad:
http://forums.autodesk.com/t5/NET/Select-Nested/m-p/2046216/highlight/true#M7899
Moderator
Alexander.Rivilis
Message 6 of 6 (212 Views)
01-11-2013 05:55 AM in reply to: fred.schippers
It is look you are right. IMHO only way is using pure ObjectARX (not AutoCAD .NET API) like this: http://adndevblog.typepad.com/autocad/2012/08/acedssget-multi-select-in-n-mode.html
Or using P/Invoke in .NET to call acedSSGet(L"_N:U:smileyvery-happy:",...);
