There are blocks in the drawing, each containing several nested entities. Need a command which would find all the nested entities which got into the selection area provided by user (not necessary to select entities, just get the ids). GetNestedEntity() does what I need but for a single entity only.
Selection of 'Trim' command does exactly what I need. How could I achieve the same behaviour?
Thank you.
@fred.schippers wrote:
... not necessary to select entities, just get the ids ...
It is easy to iterate BlockTableRecode and get all ObjectId's of subentities (except constant AttributeDefinition)
Facebook | Twitter | LinkedIn
Ok. What about Editor.GetSelection with argument PromptSelectionOptions with properties AllowSubSelections and ForceSubSelections equal true?
Doesn't work. Even blocks can not be selected in this case.
Have found similar question here, but it was not answered 😞
http://forums.autodesk.com/t5/NET/Select-Nested/m-p/2046216/highlight/true#M7899
It is look you are right. IMHO only way is using pure ObjectARX (not AutoCAD .NET API) like this: http://adndevblog.typepad.com/autocad/2012/08/acedssget-multi-select-in-n-mode.html
Or using P/Invoke in .NET to call acedSSGet(L"_N:U:D",...);
Alexander.Rivil
http://adn-cis.org/forum/index.php?topic=7683.msg25135#msg25135
Thank you
If you are still interested in selecting multiple nested entities, see if these 2 articles are of help (pure .NET API solution):
https://drive-cad-with-code.blogspot.com/2019/08/select-multiple-nested-entities-1.html
https://drive-cad-with-code.blogspot.com/2019/08/selecting-multiple-nested-entities-2-of.html
