.NET
Selection of multiple nested entities
7 REPLIES 7
Message 1 of 8
1713 Views, 7 Replies
There are blocks in the drawing, each containing several nested entities. Need a command which would find all the nested entities which got into the selection area provided by user (not necessary to select entities, just get the ids). GetNestedEntity() does what I need but for a single entity only.
Selection of 'Trim' command does exactly what I need. How could I achieve the same behaviour?
Thank you.
7 REPLIES 7
Message 2 of 8
Alexander.Rivilis
@Anonymous wrote:
... not necessary to select entities, just get the ids ...
It is easy to iterate BlockTableRecode and get all ObjectId's of subentities (except constant AttributeDefinition)
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 3 of 8
in reply to: Alexander.Rivilis
I don't need all subentities, just those selected by user.
Message 4 of 8
Alexander.Rivilis
Ok. What about Editor.GetSelection with argument PromptSelectionOptions with properties AllowSubSelections and ForceSubSelections equal true?
Expert Elite Member
Message 5 of 8
Doesn't work. Even blocks can not be selected in this case.
Have found similar question here, but it was not answered 😞
http://forums.autodesk.com/t5/NET/Select-Nested/m-p/2046216/highlight/true#M7899
Message 6 of 8
Alexander.Rivilis
It is look you are right. IMHO only way is using pure ObjectARX (not AutoCAD .NET API) like this: http://adndevblog.typepad.com/autocad/2012/08/acedssget-multi-select-in-n-mode.html
Or using P/Invoke in .NET to call acedSSGet(L"_N:U:D",...);
Expert Elite Member
Message 7 of 8
any chance of getting the sample code from the dead link from the comment in the linked post?
http://adn-cis.org/forum/index.php?topic=7683.msg25135#msg25135
Thank you
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
Message 8 of 8
@Civil3DReminders_com :
If you are still interested in selecting multiple nested entities, see if these 2 articles are of help (pure .NET API solution):
https://drive-cad-with-code.blogspot.com/2019/08/select-multiple-nested-entities-1.html
https://drive-cad-with-code.blogspot.com/2019/08/selecting-multiple-nested-entities-2-of.html
Norman Yuan
Drive CAD With Code
”Boost
