.NET
selection filter on xdata for all type of feature
7 REPLIES 7
Message 1 of 8
1650 Views, 7 Replies
i am trying to create selection set entity xdata(1001, 1000,1000)
features like text,line,lwpolyline,insert....etc.
but its working only on linear features
not working on remaining features
why?
please help me
7 REPLIES 7
Message 2 of 8
Only the 1001 group (application id) can be used as a filter.
Other XData field are not supported by the selection filtering mechanism.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6313307@discussion.autodesk.com...
why?
please help me
Message 3 of 8
Thank u tony
Why its not possible for 1000 and 1002?
Message 4 of 8
Because xdata is not supported by selection filtering.
wrote in message news:6313742@discussion.autodesk.com...
Thank u tony
Message 5 of 8
I need to reopen this discussion.
Actually "XData Value filtering" is possible, unfortunately only for some types of Entities.
I build my filter like that:
TypedValueList tvl = new TypedValueList();
tvl.Add(new TypedValue((short)DxfCode.XDataStart));
tvl.Add(new TypedValue((short)DxfCode.ExtendedDataAsciiString, xdataValue));
My filter works on MTexts, Tables, Polylines and Ellipses
It does NOT WORK for Lines, Arcs and Circles
Does anybody know the reason for that?
Message 6 of 8
465340553
I encountered the same problem
            TypedValue[] tv = new TypedValue[]
                                    new TypedValue((int)DxfCode.Operator, "<AND"),
                                    new TypedValue((int)DxfCode.Operator, "<OR"),
                                    new TypedValue((int)DxfCode.Start, "LWPOLYLINE"),
                                    new TypedValue((int)DxfCode.Start, "POLYLINE"),
                                    new TypedValue((int)DxfCode.Operator, "OR>"),
                                    new TypedValue((int)DxfCode.ExtendedDataRegAppName, Utility.AppName),
                                    new TypedValue((int)DxfCode.ExtendedDataAsciiString, "分区边界"),
                                    new TypedValue((int)DxfCode.Operator, "AND>")
My electionFilter work on LWPOLYLINE,
not work on POLYLINE,
Test with autocad 2014 and 2018
Get the same result.
王磊
您认为此帖子是否有用?欢迎为此帖点赞。
您的问题是否已得到解答?请点击“接受解答”按钮。
Message 7 of 8
_gile
in reply to: 465340553
With xdata you can only filter with the application name (see this topic).
You can try like this:
    new TypedValue(0, "*POLYLINE"),
    new TypedValue(1001, Utility.AppName)
Gilles Chanteau
GileCAD
GitHub
Message 8 of 8
465340553
in reply to: _gile
thanks
王磊
您认为此帖子是否有用?欢迎为此帖点赞。
”Boost
