.NET
mfernandes
Message 1 of 4 (380 Views)
selection filter on multiple layers
380 Views, 3 Replies
04-25-2012 11:35 PM
to select object on a single layer
Dim strLayer as string = "road"
acTypValAr.SetValue(New TypedValue(DxfCode.LayerName, strLayer), 2)
 how do you select all objects on multiple layers
Dim strLayer as string = "road,sidewalks"
 the above does not work. any suggestions how do you select all objects on multiple layers?
Alfred.NESWADBA
Message 2 of 4 (379 Views)
Re: selection filter on multiple layers
04-25-2012 11:43 PM in reply to: mfernandes
what is the question or what is not clear? To select all objects on layer "road" and all objects on layer "sidewalks" you can use the statement you showed in the second code-snippet.
Or do I misinterpret your question?
- alfred -
Alfred NESWADBA
Hallex
Message 3 of 4 (374 Views)
04-26-2012 12:40 AM in reply to: mfernandes
Try this code, tested on A2009
        <CommandMethod("multlayers", CommandFlags.UsePickSet And CommandFlags.Redraw)> _
        Public Sub SortManyLayers()
            Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            Dim height As Double = 0.2
            Dim color As Integer = 256
            Dim tid As ObjectId = ObjectId.Null
            Dim ar As New ArrayList()
            Dim tr As Transaction = db.TransactionManager.StartTransaction()
            Using tr
                Try
                    Dim pso As PromptSelectionOptions = New PromptSelectionOptions
                    pso.MessageForRemoval = vbLf + "Select circles only"
                    pso.MessageForAdding = vbLf + "Select circles"
                    Dim tv As TypedValue() = New TypedValue() {New TypedValue(0, "circle"), New TypedValue(8, "0,BORDER-A,BORDER-B,BORDER-E1")}
                    Dim flt As New SelectionFilter(tv)
                    Dim res As PromptSelectionResult
                    res = ed.GetSelection(pso, flt)
                    If res.Status <> PromptStatus.OK Then
                        Return
                    End If
                    Dim sset As SelectionSet = res.Value
                    Dim n As Integer = 0
                    For Each obj As SelectedObject In sset
                        Dim dbobj As DBObject = tr.GetObject(obj.ObjectId, OpenMode.ForRead)
                        Dim circ As Circle = TryCast(dbobj, Circle)
                        If circ IsNot Nothing Then
                            'If n = 0 Then
                            Dim pt As Point3d = circ.Center
                            Dim cid As ObjectId = circ.ObjectId
                            Dim kp As New KeyValuePair(Of ObjectId, Point3d)(cid, pt)
                            ar.Add(kp)
                            'End If
                        End If
                    Next
                    ed.WriteMessage(vbLf & "Count Circles = " + ar.Count.ToString())
                    tr.Commit()
                Catch ex As System.Exception
                    ed.WriteMessage(ex.ToString)
                Finally
                    For Each kp As KeyValuePair(Of ObjectId, Point3d) In ar
                        ed.WriteMessage(vbLf + "ObjectID: {0}" + vbTab + "Center Point: {1}", kp.Key, kp.Value)
                    Next
                End Try
            End Using
        End Sub
~'J'~
mfernandes
Message 4 of 4 (367 Views)
04-26-2012 12:53 AM in reply to: Alfred.NESWADBA
Thanks Alfred
I am working way too late into the night.
In this case I need to wipe the egg of my face.:smileyembarrassed:
I had an error in  my code in regards to my layer name, spelling. UG!!!!!!.....sorry.
so yes "Road,Sidewalks" will select all objects on layer Roads and objects on layer Sidewalks.
thanks
