.NET
selection filter on multiple layers
6 REPLIES 6
mfernandes
2224 Views, 6 Replies
to select object on a single layer
Dim strLayer as string = "road"
acTypValAr.SetValue(New TypedValue(DxfCode.LayerName, strLayer), 2)
 how do you select all objects on multiple layers
Dim strLayer as string = "road,sidewalks"
 the above does not work. any suggestions how do you select all objects on multiple layers?
6 REPLIES 6
what is the question or what is not clear? To select all objects on layer "road" and all objects on layer "sidewalks" you can use the statement you showed in the second code-snippet.
Or do I misinterpret your question?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Hallex
in reply to: mfernandes
Try this code, tested on A2009
        <CommandMethod("multlayers", CommandFlags.UsePickSet And CommandFlags.Redraw)> _
        Public Sub SortManyLayers()
            Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            Dim height As Double = 0.2
            Dim color As Integer = 256
            Dim tid As ObjectId = ObjectId.Null
            Dim ar As New ArrayList()
            Dim tr As Transaction = db.TransactionManager.StartTransaction()
            Using tr
                Try
                    Dim pso As PromptSelectionOptions = New PromptSelectionOptions
                    pso.MessageForRemoval = vbLf + "Select circles only"
                    pso.MessageForAdding = vbLf + "Select circles"
                    Dim tv As TypedValue() = New TypedValue() {New TypedValue(0, "circle"), New TypedValue(8, "0,BORDER-A,BORDER-B,BORDER-E1")}
                    Dim flt As New SelectionFilter(tv)
                    Dim res As PromptSelectionResult
                    res = ed.GetSelection(pso, flt)
                    If res.Status <> PromptStatus.OK Then
                        Return
                    End If
                    Dim sset As SelectionSet = res.Value
                    Dim n As Integer = 0
                    For Each obj As SelectedObject In sset
                        Dim dbobj As DBObject = tr.GetObject(obj.ObjectId, OpenMode.ForRead)
                        Dim circ As Circle = TryCast(dbobj, Circle)
                        If circ IsNot Nothing Then
                            'If n = 0 Then
                            Dim pt As Point3d = circ.Center
                            Dim cid As ObjectId = circ.ObjectId
                            Dim kp As New KeyValuePair(Of ObjectId, Point3d)(cid, pt)
                            ar.Add(kp)
                            'End If
                        End If
                    Next
                    ed.WriteMessage(vbLf & "Count Circles = " + ar.Count.ToString())
                    tr.Commit()
                Catch ex As System.Exception
                    ed.WriteMessage(ex.ToString)
                Finally
                    For Each kp As KeyValuePair(Of ObjectId, Point3d) In ar
                        ed.WriteMessage(vbLf + "ObjectID: {0}" + vbTab + "Center Point: {1}", kp.Key, kp.Value)
                    Next
                End Try
            End Using
        End Sub
~'J'~
Thanks Alfred
I am working way too late into the night.
In this case I need to wipe the egg of my face.Smiley Embarassed
I had an error in  my code in regards to my layer name, spelling. UG!!!!!!.....sorry.
so yes "Road,Sidewalks" will select all objects on layer Roads and objects on layer Sidewalks.
thanks
BKSpurgeon
HI
I"m not expert, but i'm not sure that it will. how will autocad know that the comma acts as an OR operator (||)
Kean W has answered your exact question in a comment in the post below:
http://through-the-interface.typepad.com/through_the_interface/2008/05/finding-all-the.html
gluckand i hope this helps.
rgds
BK
SENL1362
in reply to: BKSpurgeon
The "," is an illegal (layer) name character. Try creating a new layer using the input "a,b". It will create two layers: a and b.
Also the "|" is an illegal character, it's reserved to separate the current drawing layername with the Xref layername.
Both methodes
1. Name1, name2
2. OR Name1, Name2, ...
can be used to select items from several layers.
_gile
All string value in selection filter TypedValueS as DxfCode.LayerName (8), DxfCode.Start (0), DxfCode.BlockName (2), and so on, can use wildcard patterns.
Have a look at the help docs:
http://help.autodesk.com/view/ACD/2016/ENU/?guid=GUID-3C1A759C-BB88-41A7-B1DE-697C493C92C8
Gilles Chanteau
GileCAD
GitHub
”Boost
