.NET
selection filer typedvalue between X and between Y
5 REPLIES 5
kbarnettza
1682 Views, 5 Replies
AutoCAD 2012
C#
Windows 7
I need a selection filter to find text objects within a rectangular area using dxf operators (do not want to use Editor.SelectWindow).
Whats wrong with the following code attempt?
It causes Fatal Error!
Thx.. Kevn..
TypedValue[] tv2 = new TypedValue[15];
tv2.SetValue(new TypedValue((int)DxfCode.Start, "TEXT"), 0);
tv2.SetValue(new TypedValue((int)DxfCode.Operator, "<and"), 1);
tv2.SetValue(new TypedValue((int)DxfCode.Operator, "<and"), 2);
tv2.SetValue(new TypedValue((int)DxfCode.Operator, ">"), 3);
tv2.SetValue(new TypedValue((int)DxfCode.XCoordinate,
Match1[0].GeometricExtents.MinPoint.X - 20), 4);
tv2.SetValue(new TypedValue((int)DxfCode.Operator, "<"), 5);
Match1[0].GeometricExtents.MaxPoint.X + 20), 6);
tv2.SetValue(new TypedValue((int)DxfCode.Operator, "and>"), 7);
tv2.SetValue(new TypedValue((int)DxfCode.Operator, "<and"), 8);
tv2.SetValue(new TypedValue((int)DxfCode.Operator, ">"), 9);
tv2.SetValue(new TypedValue((int)DxfCode.YCoordinate,
Match1[0].GeometricExtents.MinPoint.Y + 109), 10);
tv2.SetValue(new TypedValue((int)DxfCode.Operator, "<"), 11);
Match1[0].GeometricExtents.MaxPoint.Y + 131), 12);
tv2.SetValue(new TypedValue((int)DxfCode.Operator, "and>"), 13);
tv2.SetValue(new TypedValue((int)DxfCode.Operator, "and>"), 14);
SelectionFilter sf2 = new SelectionFilter(tv2);
PromptSelectionResult psr2 = AcadDoc1.Editor.SelectAll(sf2);
5 REPLIES 5
kbarnettza
in reply to: kbarnettza
.. this also did not work ... fatal error ...
TypedValue[] tv2 =
new TypedValue[]
new TypedValue((int)DxfCode.XCoordinate, Match1[0].GeometricExtents.MinPoint.X - 20),
new TypedValue((int)DxfCode.XCoordinate, Match1[0].GeometricExtents.MaxPoint.X + 20),
new TypedValue((int)DxfCode.YCoordinate, Match1[0].GeometricExtents.MinPoint.Y + 109),
new TypedValue((int)DxfCode.YCoordinate, Match1[0].GeometricExtents.MaxPoint.Y + 131),
Hallex
See if this working for you,
I used Polyline instead of "unknown Match[0]" on my machine:
                    Extents3d ext = pline.GeometricExtents;
                    double xmin = ext.MinPoint.X - 20;
                    double ymin = ext.MinPoint.Y + 109;
                    double xmax = ext.MaxPoint.X + 20;
                    double ymax = ext.MaxPoint.Y + 131;
                    Point3d minpt = new Point3d(xmin, ymin, pline.Elevation).TransformBy(Matrix3d.Identity);
                    Point3d maxpt = new Point3d(xmax, ymax, pline.Elevation).TransformBy(Matrix3d.Identity);
                    string tab = (string)Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("CTAB");
                    TypedValue[] tvs = new TypedValue[] {
              new TypedValue((int) DxfCode.Start, "TEXT"),
              new TypedValue(410, tab),
               new TypedValue((int) DxfCode.Operator, "<AND"),
              new TypedValue((int)  DxfCode.Operator, ">,>,*"),
              new TypedValue((int) 10, minpt),
              new TypedValue((int) DxfCode.Operator, "<,<,*"),
              new TypedValue((int) 10, maxpt),
              new TypedValue((int) DxfCode .Operator, "AND>")
                    SelectionFilter sf = new SelectionFilter(tvs);
                    PromptSelectionResult psr = ed.SelectAll(sf);
                    if (psr.Status == PromptStatus.OK)
                        count = psr.Value.GetObjectIds().Length;
                        ed.WriteMessage("\nSelected:    " + count.ToString());
                    else
                        ed.WriteMessage("\nBad selection");
                        return;
                    tr.Commit();
~'J'~
kbarnettza
in reply to: Hallex
Dude! You ROCK! Thanks!
Hallex
Glad to help Smiley Happy
~'J'~
amitnkukanur
in reply to: Hallex
Hi Hallex,
I have two confusions
1) I am using COM objects, in this case will this logic work.
2) On what basis is Pline initialised.
Please reply.
rgds
Amit
Senior Software Engineer
”Boost
