.NET
Selecting objects on screen from Handle or ObjectID
6 REPLIES 6
greg
1002 Views, 6 Replies
If I have a list of handles for Autocad Entities, how would I go about selecting these entities on screen so that the user could add to this selection or remove objects from the selection?  I could go with objectids as well if needed.
I have been searching and searching and coming up empty handed or at least coming up with information that doesnt seem to dowhat I want.
6 REPLIES 6
Alexander.Rivilis
in reply to: greg
Method Editor.SelectImplied can help you. Command must be registered with CommandFlags.Redraw | CommandFlags.UsePickSet attributes
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
greg
in reply to: Alexander.Rivilis
Hi Alexander,
I am not sure where to head with this.  I attempted but just not sure what to do.  Do I need to build a selection set within code?  Can you do that without prompting a user for selections?  I guess I am a bit lost now.
Thanks for your help!  Greatly appreciated!
greg
In addition, I have tried using:
Autodesk.AutoCAD.Internal.Utils.SelectObjects(anobjectid)
but when I use an objectId in that line I get a message that :
Value of type 'System.Collections.Generic.List(Of Autodesk.AutoCAD.DatabaseServices.ObjectId)' cannot be converted to '1-dimensional array of Autodesk.AutoCAD.DatabaseServices.ObjectId'
thanks,
greg
Nevermind.  I finally got the code to work I think.  it is as follows:
Dim ids(0) As ObjectId
ids(0) = ObjectIdFromHandle(myDocDB, "1D6")
Autodesk.AutoCAD.Internal.Utils.SelectObjects(ids)
greg
in reply to: greg
I guess this may not work because you not already in a command?
greg
in reply to: greg
Okay, I think I got some of this to work.  My only issue is that how do I stop and allow the user to add or remove from the current on screen selection.  This is what I have so far but i never get prompted to revise the selection.
                Dim ids(1) As ObjectId
                ids(1) = ObjectIdFromHandle(myDocDB, "1DE")
                Dim prObjectSelectionOptions As PromptSelectionOptions = New PromptSelectionOptions()
                prObjectSelectionOptions.MessageForAdding = vbCrLf & "Please revise polyline selection:"
                '  Prompt for selections
                Dim prObjectSelectionRes As PromptSelectionResult = ed.SelectImplied()
                '  I am then trying to allow the user to add additional selections, or remove here
                prObjectSelectionRes = ed.GetSelection(prObjectSelectionOptions)
”Boost
