.NET
Active Contributor
greg
Message 1 of 7 (306 Views)
Selecting objects on screen from Handle or ObjectID
306 Views, 6 Replies
02-15-2013 02:14 PM
If I have a list of handles for Autocad Entities, how would I go about selecting these entities on screen so that the user could add to this selection or remove objects from the selection?  I could go with objectids as well if needed.
I have been searching and searching and coming up empty handed or at least coming up with information that doesnt seem to dowhat I want.
Moderator
Alexander.Rivilis
Message 2 of 7 (303 Views)
Re: Selecting objects on screen from Handle or ObjectID
02-15-2013 02:24 PM in reply to: greg
Method Editor.SelectImplied can help you. Command must be registered with CommandFlags.Redraw | CommandFlags.UsePickSet attributes
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Active Contributor
greg
Message 3 of 7 (279 Views)
02-15-2013 05:12 PM in reply to: Alexander.Rivilis
Hi Alexander,
I am not sure where to head with this.  I attempted but just not sure what to do.  Do I need to build a selection set within code?  Can you do that without prompting a user for selections?  I guess I am a bit lost now.
Thanks for your help!  Greatly appreciated!
Active Contributor
greg
Message 4 of 7 (277 Views)
02-15-2013 05:27 PM in reply to: Alexander.Rivilis
In addition, I have tried using:
Autodesk.AutoCAD.Internal.Utils.SelectObjects(anobjectid)
but when I use an objectId in that line I get a message that :
Value of type 'System.Collections.Generic.List(Of Autodesk.AutoCAD.DatabaseServices.ObjectId)' cannot be converted to '1-dimensional array of Autodesk.AutoCAD.DatabaseServices.ObjectId'
thanks,
Active Contributor
greg
Message 5 of 7 (275 Views)
02-15-2013 05:32 PM in reply to: Alexander.Rivilis
Nevermind.  I finally got the code to work I think.  it is as follows:
Dim ids(0) As ObjectId
ids(0) = ObjectIdFromHandle(myDocDB, "1D6")
Autodesk.AutoCAD.Internal.Utils.SelectObjects(ids)
Active Contributor
greg
Message 6 of 7 (272 Views)
02-15-2013 05:45 PM in reply to: greg
I guess this may not work because you not already in a command?
Active Contributor
greg
Message 7 of 7 (262 Views)
02-15-2013 06:32 PM in reply to: greg
Okay, I think I got some of this to work.  My only issue is that how do I stop and allow the user to add or remove from the current on screen selection.  This is what I have so far but i never get prompted to revise the selection.
                Dim ids(1) As ObjectId
                ids(1) = ObjectIdFromHandle(myDocDB, "1DE")
                Dim prObjectSelectionOptions As PromptSelectionOptions = New PromptSelectionOptions()
                prObjectSelectionOptions.MessageForAdding = vbCrLf & "Please revise polyline selection:"
                '  Prompt for selections
                Dim prObjectSelectionRes As PromptSelectionResult = ed.SelectImplied()
                '  I am then trying to allow the user to add additional selections, or remove here
                prObjectSelectionRes = ed.GetSelection(prObjectSelectionOptions)
