.NET
hassanhafeez33
Message 1 of 5 (197 Views)
Selecting lines around an intersection point with a reference line
197 Views, 4 Replies
09-17-2011 04:13 AM
Hi All,
Is it possible to select lines (maybe up to 6 lines) around an intersection point  with a reference line. There is one intersection point and the lines are around it. And also, both the intersecting lines are in different layers.
Once I have any idea, Maybe I can get on with my project. And if someone could tell me how to get the ObjectARX's ArxDbg tool working on autocad 2012, it would be great help. ObjectARX 2010 sample project fails to open in VS2010 express.
Thanks in Advance!
Cheers
I personally would use a for each o search through th lines to your matchiing criteria, then open them for write as a new line and do with them as you need.
Cheers,  Quigs.
hassanhafeez33
Message 2 of 5 (193 Views)
Re: Selecting lines around an intersection point with a reference line
09-17-2011 07:05 AM in reply to: hassanhafeez33
As of now, I am able to get a selection from user and filtering out the reference line or the lines around the intersection point. The problem is, I want to make the program do the selection as well, and I have no clue.
Distinguished Contributor
quigs
Message 3 of 5 (184 Views)
09-17-2011 07:56 AM in reply to: hassanhafeez33
please forgive me if have missed the point, are you having trouble selecting
the outer lines programmatically?  If so you can use the bellow code to
make a case selection.  The filter specifically looks for 2d poly lines, but you
could just search for the object type you need.
Select Case myEnt.ObjectId.ObjectClass.Name
  Case "AcDb2dPolyline"
    Dim SelInt As PromptSelectionResult = acDoc.Editor.SelectCrossingWindow(New Point3d(PntOnLn.X + 1.6, PntOnLn.Y + 1.6, 0), New Point3d(PntOnLn.X - 1.6, PntOnLn.Y - 1.6, 0))
     End Select
End Select
Cheers,
Martin
My name is Martin.. :smileyvery-happy:
hassanhafeez33
Message 4 of 5 (175 Views)
09-17-2011 12:04 PM in reply to: quigs
Thanks Quigs, yes the point is to select the outer lines programmatically.  but the eventual aim of my project is to search for these lines along the various intersection points along the y axis (increasing), and move them one by one ( i-e move to a different geometric location after selection around first intersection and then look and select the next set of lines).
Am I supposed to have a record table of some sort? or just loop through the set of coordinates and thence select and move the lines?
Thanks again for taking the time to reply! I hope one day Ill be able to help someone aswell :smileyhappy:
quigs
Message 5 of 5 (168 Views)
09-17-2011 05:23 PM in reply to: hassanhafeez33
Cheers,  Quigs.
