.NET
f.roels
Message 1 of 5 (324 Views)
selecting blocks, entities
324 Views, 4 Replies
07-12-2013 07:35 AM
I have some blocks which are placed with some routines in VB.net and are linked by a unique code to a external data file (XML-file). I want to try to created a kind of propertybox (in a toolpalette) which indicate some of this external data values. If one of these values are changed (by changing the values in the propertybox), some routines need to be executed.
So my question is, is it possible when a object is selected (not during a command), to run a piece of code (VB.NET). I have found some basic principles about "overruling" but I'm not sure this is the correct/possible way to solve the problem and I'm not there yet.
Can somebody help me with some sample code in VB.NET?
thx
Filip
You can handle the Document.ImpliedSelectionChanged event.
Here's a little sample.
C#
 [CommandMethod("On")]
public void On()
Document doc = AcAp.DocumentManager.MdiActiveDocument;
doc.ImpliedSelectionChanged += new EventHandler(doc_ImpliedSelectionChanged);
[CommandMethod("Off")]
public void Off()
doc.ImpliedSelectionChanged -= new EventHandler(doc_ImpliedSelectionChanged);
void doc_ImpliedSelectionChanged(object sender, EventArgs e)
Document doc = (Document)sender;
Editor ed = doc.Editor;
PromptSelectionResult psr = ed.SelectImplied();
if (psr.Status == PromptStatus.OK)
AcAp.ShowAlertDialog(string.Format("{0} selected entities", psr.Value.Count));
VB
 <CommandMethod("On")> _
Public Sub [On]()
Dim doc As Document = Application.DocumentManager.MdiActiveDocument
AddHandler doc.ImpliedSelectionChanged, AddressOf doc_ImpliedSelectionChanged
End Sub
<CommandMethod("Off")> _
Public Sub Off()
RemoveHandler doc.ImpliedSelectionChanged, AddressOf doc_ImpliedSelectionChanged
End Sub
Private Sub doc_ImpliedSelectionChanged(sender As Object, e As EventArgs)
Dim doc As Document = DirectCast(sender, Document)
Dim ed As Editor = doc.Editor
Dim psr As PromptSelectionResult = ed.SelectImplied()
If psr.Status = PromptStatus.OK Then
Application.ShowAlertDialog(String.Format("{0} selected entities", psr.Value.Count))
End If
End Sub
_gile
Message 2 of 5 (310 Views)
Re : selecting blocks, entities
07-12-2013 08:16 AM in reply to: f.roels
Gilles Chanteau
_gile
Message 3 of 5 (306 Views)
07-12-2013 08:31 AM in reply to: f.roels
C#
        public void On()
        public void Off()
VB
        Public Sub [On]()
        End Sub
        Public Sub Off()
        End Sub
            End If
        End Sub
Gilles Chanteau
_gile
Message 4 of 5 (300 Views)
07-12-2013 09:03 AM in reply to: _gile
You can also handle the DBObject.Modified event for you blocks.
Gilles Chanteau
f.roels
Message 5 of 5 (212 Views)
07-30-2013 08:13 AM in reply to: _gile
Hi Gilles,
thanks for your reply. Using your code/example I managed to reach my goal.
best
Filip
