.NET
Valued Contributor
scluna
Message 1 of 5 (296 Views)
Accepted Solution
Selecting All Overlapping Polylines
296 Views, 4 Replies
02-26-2014 01:35 PM
Does anyone knows how querying drawing using autocad api (.net) and selecting all overlapping polygon?
Please refer to attached picture of overlapping polyline.
Thanks and regards
SCLuna
SENL1362
Message 2 of 5 (258 Views)
Re: Selecting All Overlapping Polylines
02-27-2014 10:06 AM in reply to: scluna
Get inspired by Regions and their methods to identify points inside them. Credits to Tony.
http://forums.autodesk.com/t5/NET/Find-entities-in-region/m-p/4772867#M38830
Start with boundary min/max point test against each other .
Then when the inside tests are positive continue with their actual vertices.
Valued Contributor
scluna
Message 3 of 5 (233 Views)
02-28-2014 01:39 PM in reply to: SENL1362
Is there another method to do this. Although the scripts does the job it is too slow beacuse I will need to convert polyline to region and get all points /vertices of each polyline I will compare with the region?
There is a method I saw GetLineContainment, but I am not familiar with how to use it.
Thanks and regards,
SCLuna
SENL1362
Message 4 of 5 (225 Views)
02-28-2014 10:45 PM in reply to: scluna
the alternative i know of is to do the math your self, ie. calc the in/outside status of vertices within closed area's.
sorry.
Valued Contributor
scluna
Message 5 of 5 (197 Views)
03-03-2014 06:58 AM in reply to: SENL1362
I see. The link you gave is quite helpful.
Thank you and regards.
SCLuna
Announcements
Need installation help?
