.NET
Selecting a single entity.
3 REPLIES 3
486 Views, 3 Replies
With LISP I can force my selection to be a single entity and of a certain type. I have been able to restrict the type of entity I am selecting, but I have not been able to figure out how to restrict my selection to a single entity pick. My program must not allow more than one entity to be selected or it will not be able to perform the required function.
Any help is appreciated.
Scott
3 REPLIES 3
chiefbraincloud
You use Editor.GetEntity... but assuming you are currently using the selection methods, the way you tell GetEntity to only allow a certain type of object is different than the filtering in selection sets. You have to call SetRejectMessage, then AddAllowedClass on the PromptEntityOptions. Here is a simple example, which returns through byref arguments. You use the AllowedType argument by passing GetType(BlockReference) for example.
Friend Shared Sub EntSelect(ByRef SelObj As ObjectId, ByRef PickPoint As Point3d, ByVal PromptString As String, ByVal AllowedType As System.Type, ByVal RejectMsg As String)
SelObj = Nothing
Dim ed As Editor = AppServ.Application.DocumentManager.MdiActiveDocument.Editor
Try
Dim prEntOps As New PromptEntityOptions(PromptString)
Dim prEntRes As PromptEntityResult
prEntOps.SetRejectMessage(RejectMsg)
prEntOps.AddAllowedClass(AllowedType, True)
prEntOps.AllowNone = False
prEntOps.AllowObjectOnLockedLayer = True
prEntOps.AppendKeywordsToMessage = False
prEntRes = ed.GetEntity(prEntOps)
If prEntRes.Status <> PromptStatus.OK Then Return
PickPoint = prEntRes.PickedPoint
SelObj = prEntRes.ObjectId
Catch ex As System.Exception
ed.WriteMessage(ex.Message & " In: " & ex.Source & vbCrLf & ex.StackTrace & vbCrLf)
Return
Finally
ed = Nothing
End Try
End Sub
You can use the Editor's GetEntity() method to select a
single
object (which is equivalent to LISP's (entsel)
function).
You can also restrict the selection to a certain type of
object
using the AddAllowedClass() method of the
PromptEntityOptions
class (but you must call the SetRejectMessage() method
first).
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000
through 2009
href="http://www.acadxtabs.com">http://www.acadxtabs.com
With
be able to perform the required function. Any help is appreciated.
Scott
Thanks, based on the answers here I was able to come up with the following to get what I needed.
Dim myPrmpt1 As New EditorInput.PromptSelectionOptions
myPrmpt1.AllowDuplicates = False
myPrmpt1.SinglePickInSpace = True
myPrmpt1.SingleOnly = True
myPrmpt1.AllowSubSelections = False
myPrmpt1.RejectObjectsFromNonCurrentSpace = True
myPrmpt1.MessageForAdding = "Select text entity to duplicate: "
myTV(0) = New DatabaseServices.TypedValue(0, "TEXT,MTEXT")
Dim myFilter As New EditorInput.SelectionFilter(myTV)
myTPSR = myEd.GetSelection(myPrmpt1, myFilter)
Works great.
Scott
”Boost
