.NET
SelectImplied of SelectionSet sample in ObjectARX does not work?
1 REPLY 1
wesbird
440 Views, 1 Reply
HI,
I tried the SelectionSet sample in ObjectARX. command Implied does not work.
What I did, I select something(arc, circle, line ...) in the drawing, with the grip highlight, type Implied on AutoCAD command line, return nothing.
when I debug into, it return from this line:
If res.Status = PromptStatus.Error Then Return
Is the way I select wrong?
Thank you,
Merry Christmas
Wes
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
1 REPLY 1
wesbird
in reply to: wesbird
please ignore this. I got it:
CommandFlags.UsePickSet
”Boost
