.NET
Select Objects
2 REPLIES 2
229 Views, 2 Replies
Select Objects
Have I understood this correctly: It is only possible to create a selection
in Acad through .NET with editor.SelectAll(filter) method. SelectAll(filter)
ignores Handles or ObjectNames as typed values. If I have, here is the
question: is there any workaroud for this? Is there any way to make a
selection in Acad if I have the ObjectsIds (or Handles) for the objects that
I want to select? And I really mean that I need to select the objects in
Acad UI. I am not going to collect any data from the selection - I just need
to select the objects (the other possibility would be to create my own
Properties palette - and I don't want to go there...).
/ Tomi
2 REPLIES 2
ognyandim
Try to mod and use this.
ognyandim
Ops. Here is the link
http://discussion.autodesk.com/thread.jspa?messageID=5096504
”Boost
