.NET
Select All
10 REPLIES 10
Message 1 of 11
amitnkukanur
2296 Views, 10 Replies
Select All
The below code is one part of code which am using now and i got this solutions here only. Now comming to problem: i am trying my best for select all from screen without opening AutoCAD but they are not successful.
Can any one alter this piece of code so that it will select all without opening CAD
Regards
Amit
Public Shared Sub ReadTexts()
Dim acadver As String = "18" '//AutoCAD Version
' Set your file name to read data here
'Dim fname As String = "C:\Test\tags.dwg"
 ' Define csv file name variable
Dim csvname As String = String.Empty
Dim listData As New List(Of Object)
' Get current culture
Dim oldCult As System.Globalization.CultureInfo = System.Threading.Thread.CurrentThread.CurrentCulture
' Create new culture
Dim thisCult As System.Globalization.CultureInfo = New System.Globalization.CultureInfo("en-US")
' Set current culture to newly created
System.Threading.Thread.CurrentThread.CurrentCulture = thisCult
MsgBox("Wait...")
Dim appProgID As String = "Autocad.Application" + "." + acadver
' Get reference on interface IDispatch
Dim AcadType As Type = Type.GetTypeFromProgID(appProgID)
' Run AutoCAD
Dim AcadApp As Object = Activator.CreateInstance(AcadType)
Dim visargs() As Object = New Object(0) {}
' Set visibility mode to true
visargs(0) = False
' Make application visible
AcadApp.GetType().InvokeMember("Visible", BindingFlags.SetProperty, Nothing, AcadApp, visargs, Nothing)
' Maximize window
AcadApp.GetType().InvokeMember("WindowState", BindingFlags.SetProperty, Nothing, AcadApp, New Object() {1}, Nothing)
Dim AcadDocs As Object = AcadApp.GetType().InvokeMember("Documents", BindingFlags.GetProperty, Nothing, AcadApp, Nothing)
' Define arguments to open file
Dim args() As Object = New Object(1) {}
args(0) = fname
' Set read only mode to true
args(1) = False
' Try open document
Dim AcDoc As Object = AcadDocs.GetType.InvokeMember("Open", BindingFlags.InvokeMethod, Nothing, AcadDocs, args, Nothing)
Dim AcUtil As Object = New Object
Try
' get reference on active document
AcDoc = AcadApp.GetType.InvokeMember("ActiveDocument", BindingFlags.GetProperty, Nothing, AcadApp, Nothing, Nothing)
' Get reference on ModelSpace
Dim AcSpace As Object = AcDoc.GetType.InvokeMember("ModelSpace", BindingFlags.GetProperty, Nothing, AcDoc, Nothing)
' get reference on Utility
AcUtil = AcDoc.GetType.InvokeMember("Utility", BindingFlags.GetProperty, Nothing, AcDoc, Nothing, Nothing)
' get reference on SelectionSets
Dim AcSsets As Object = AcDoc.GetType.InvokeMember("SelectionSets", BindingFlags.GetProperty, Nothing, AcDoc, Nothing, Nothing)
' Perform zooming
AcadApp.GetType.InvokeMember("ZoomExtents", BindingFlags.InvokeMethod, Nothing, AcadApp, Nothing, Nothing)
' Perform zooming
AcadApp.GetType.InvokeMember("ZoomScaled", BindingFlags.InvokeMethod, Nothing, AcadApp, New Object() {0.8, 1})
' Add prompt to the command line
'AcUtil.GetType.InvokeMember("Prompt", BindingFlags.InvokeMethod, Nothing, AcUtil, New Object() {vbLf & " >> SELECT TEXTS ON SCREEN >> "})
' Add SelectionSet, named "$SelectionTest$"
AcSsets.GetType.InvokeMember("Add", BindingFlags.InvokeMethod, Nothing, AcSsets, New Object() {"$SelectionTest$"})
' Get reference on newly created Selection Set
Dim AcSset As Object = AcSsets.GetType.InvokeMember("Item", BindingFlags.InvokeMethod Or BindingFlags.GetProperty, Nothing, AcSsets, New Object() {"$SelectionTest$"})
' Create filter to use attributed blocks
Dim selargs As Object() = New Object(1) {}
Dim ftype As Short() = New Short() {0}
Dim fdata As Object() = New Object() {"*TEXT"}
selargs(0) = DirectCast(ftype, Object)
selargs(1) = DirectCast(fdata, Object)
' Perform selection on screen
'AcSset.GetType.InvokeMember("SelectOnScreen", BindingFlags.InvokeMethod, Nothing, AcSset, selargs)
' Get number of selected items
Dim cnt As Integer = CInt(AcSset.GetType.InvokeMember("Count", BindingFlags.GetProperty, Nothing, AcSset, Nothing))
AcUtil.GetType.InvokeMember("Prompt", BindingFlags.InvokeMethod, Nothing, AcUtil, New Object() {vbLf & "--> Selected Mtexts -->" & vbTab & cnt.ToString()})
' Loop through selected objects
For n As Integer = 0 To cnt - 1
' Get single item from selection
Dim AcSelItem As Object = AcSset.GetType.InvokeMember("Item", BindingFlags.InvokeMethod, Nothing, AcSset, New Object() {n})
' Get Object name
Dim objName As String = AcSelItem.GetType.InvokeMember("ObjectName", BindingFlags.GetProperty, Nothing, AcSelItem, Nothing).ToString()
Dim textStr As String = String.Empty
If objName = "AcDbText" Then
textStr = AcSelItem.GetType.InvokeMember("TextString", BindingFlags.GetProperty, Nothing, AcSelItem, Nothing).ToString()
ElseIf objName = "AcDbMText" Then
End If
listData.Add(textStr)
Next
Dim initDir As String = AcDoc.GetType.InvokeMember("Path", BindingFlags.GetProperty, Nothing, AcDoc, Nothing, Nothing).ToString()
Dim saveFileDialog As New System.Windows.Forms.SaveFileDialog
saveFileDialog.Title = "Enter a file name to write data: "
saveFileDialog.InitialDirectory = initDir
saveFileDialog.RestoreDirectory = True
saveFileDialog.Filter = "CSV files | *.csv"
saveFileDialog.FileName = "File name without extension"
Dim result As System.Windows.Forms.DialogResult = saveFileDialog.ShowDialog()
If result <> DialogResult.OK Then
csvname = "Not saved"
Return
End If
csvname = saveFileDialog.FileName
' Write data
Using sw As New StreamWriter(csvname, True, Encoding.ASCII)
For Each strline As String In listData
sw.WriteLine(strline)
Next
sw.Flush()
sw.Close()
End Using
'Save document
Dim closeargs() As Object = New Object(1) {}
closeargs(0) = True
' with the same name
closeargs(1) = fname
' Try close document
' Simplified syntax
AcDoc.GetType().InvokeMember("Close", BindingFlags.InvokeMethod, Nothing, AcDoc, closeargs)
' Try quit application
AcadApp.GetType().InvokeMember("Quit", BindingFlags.InvokeMethod, Nothing, AcadApp, Nothing)
Catch ex As System.Exception
MsgBox("Error: " & ex.Message & vbLf & "Trace: " & ex.StackTrace)
Finally
' clean up the memory
' release Utility.
releaseObject(AcUtil)
' release Document.
releaseObject(AcDoc)
' release Documents.
releaseObject(AcadDocs)
' release Application.
releaseObject(AcadApp)
' call garbage cleaner immediatelly
GC.WaitForPendingFinalizers()
GC.GetTotalMemory(True)
' restore current culture
System.Threading.Thread.CurrentThread.CurrentUICulture = oldCult
'Display result
MsgBox("Csv file saved as : " + csvname)
End Try
End Sub
Senior Software Engineer
10 REPLIES 10
Message 2 of 11
Hallex
in reply to: amitnkukanur
Try another one
    Public Shared Sub ReadTextFromModel()
        MsgBox("Wait...")
        ' Run AutoCAD
        ' Set visibility mode to false
        visargs(0) = False
        ' Maximize window
        ''AcadApp.GetType().InvokeMember("WindowState", BindingFlags.SetProperty, Nothing, AcadApp, New Object() {1}, Nothing)
        args(0) = fname
        ' Set read only mode to false
        args(1) = False
        ' Try open document
        Try
            Dim entCount As Integer = Convert.ToInt32(AcSpace.GetType.InvokeMember("Count", BindingFlags.GetProperty, Nothing, AcSpace, Nothing))
            For index As Integer = 0 To entCount - 1
                Dim AcEnt As Object = AcSpace.GetType.InvokeMember("Item", BindingFlags.InvokeMethod, Nothing, AcSpace, New Object() {index})
                ' Get Object name
                Dim objName As String = AcEnt.GetType.InvokeMember("ObjectName", BindingFlags.GetProperty, Nothing, AcEnt, Nothing).ToString()
                    textStr = AcEnt.GetType.InvokeMember("TextString", BindingFlags.GetProperty, Nothing, AcEnt, Nothing).ToString()
                End If
            Next
                Return
            End If
            ' Write data
                Next
                sw.Flush()
                sw.Close()
            End Using
            'Save document
            closeargs(0) = True
            ' Simplified syntax
        Finally
            ' release Document.
            'Display result
        End Try
    End Sub
~'J'~
Message 3 of 11
norman.yuan
Oooh, why do you need to do all the late-binding if you specifcally want to run the code against Acad version 18 (2010)? Have you debugged line by line? What is it that you cannot just set reference to Acad type library and have strongly typed variables (so that it is easier to debug)?
If you have to use late-binding for a mystical reason, you 'd better just started with early-binding to make sure your logic works (it looked like you are still not very familar with Acad programming), worked out all potential issues, then convert it to late-binding with all that "InvokeMember/InvokeMethod" calls, which you do not get intellisense prompt for and thus is error-prone process.
Norman Yuan
Drive CAD With Code
Message 4 of 11
amitnkukanur
Perfect, Thankyou Hallex It worked really Great.
Thankyou Hallex for Supporting me.
Thankyou
Regards
Amit
Message 5 of 11
amitnkukanur
But if i replace TextString by Origins or Points can i get the Starting location/Mid Point of Texts. So that i will write another logic by specifying Points and search in range to get texts
Message 6 of 11
Hallex
Glad if you got it to work
Cheers Smiley Happy
~'J'~
Message 7 of 11
Hallex
In this case you need to calculate a mid point,
based on "GetBoundingBox" method of
the text
I havent have an example of the code and also
I'm busy on today with my own...
~'J'~
Message 8 of 11
amitnkukanur
Ok Hallex i will Work on it using GetBoundingBox method of Texts. Thanks for Reply.
With Warm Regards
Amit
Message 9 of 11
Hallex
Try this code, I've found the code written by great TT,
in the midpoint of text bounds this will draw a blue circles
for imagination:
Imports System.IO
Imports System.Text
Imports System.Runtime.InteropServices
Imports System.Reflection
Imports System.Globalization
Imports System.Collections
   ' sample aux
    Public Shared Function DrawCircle(ByVal oBlock As Object, ByVal p() As Double, ByVal rad As Double) As Object
        args(0) = p
        args(1) = rad
        Dim oCirc As Object = oBlock.GetType.InvokeMember("AddCircle", BindingFlags.InvokeMethod, Nothing, oBlock, args)
        Dim norm() As Double = New Double() {0.0, 0.0, 1.0}
        oCirc.GetType().InvokeMember("Normal", BindingFlags.SetProperty, Nothing, oCirc, New Object() {norm})
        Return oCirc
    End Function
    Public Shared Sub ImportTextFromModel()
        Dim fname As String = "C:\Test\mtext.dwg"
        MsgBox("Wait...")
        ' Run AutoCAD
        visargs(0) = False
        ' Maximize window
        args(0) = fname
        args(1) = False
        ' Try open document
        Try
                ' Get Object name
                    '_____________________________________________
                    ' written by Tony Tanzillo
                    ' The array of arguments that will be passed
                    ' to the AcadEntity.GetBoundingBox() method:
                    Dim boxargs As Object() = New Object(1) {}
                    ' In order to get VT_BYREF | VT_VARIANT arguments to be
                    ' filled in by the callee, we must use VariantWrappers
                    ' as the arguments:
                    ' The callee will replace the VariantWrappers
                    ' in the args[] argument array with the results.
                    boxargs(0) = New VariantWrapper(0)
                    boxargs(1) = New VariantWrapper(0)
                    ' We also need to tell the marshaler that
                    ' both parameters in the COM method call are
                    ' 'out' or 'byref' parameters:
                    ' 2 = the total number of arguments passed:
                    Dim pm As New ParameterModifier(2)
                    pm(0) = True
                    ' first argument is byref
                    pm(1) = True
                    ' second argument is byref
                    Dim modifiers As ParameterModifier() = New ParameterModifier() {pm}
                    ' Invoke the method, passing the arguments, and
                    ' the parameter modifers
                    AcEnt.GetType().InvokeMember("GetBoundingBox", BindingFlags.InvokeMethod, Nothing, AcEnt, boxargs, modifiers, Nothing, Nothing)
                    ' The results are now in the args[] array:
                    Dim ll As Double() = DirectCast(boxargs(0), Double())
                    Dim ur As Double() = DirectCast(boxargs(1), Double())
                    '________________________________________________________
                    'dispay result (debug only)
                    'MessageBox.Show(String.Format("Point is ({0:f3} , {1:f3} , {2:f3})", ll(0), ll(1), ll(2)))
                    'draw circle in the midpont of text bounds
                    Dim midPt() As Double = New Double() {(ll(0) + ur(0)) / 2, (ll(1) + ur(1)) / 2, (ll(2) + ur(2)) / 2}
                    DrawCircle(AcSpace, midPt, 0.5)
                End If
            Next
                Return
            End If
            ' Write data to CSV
                Next
            End Using
            'Save document
            closeargs(0) = True
            ' Simplified syntax
        Finally
            ' release Document.
            'Display result
        End Try
    End Sub
~'J'~
Message 10 of 11
amitnkukanur
Perfect, it worked Hallex. Thank you Hallex Thanks a Lot
Message 11 of 11
Hallex
You're welcome,
Cheers Smiley Happy
~'J'~
”Boost
