.NET
Select all object in the drawing
3 REPLIES 3
3715 Views, 3 Replies
How can I select all the objects (lines, plylines, etc) in the drawing using C# + AutoCad?
AcadSelectionSet select = _acadCurrentDocument.SelectionSets.Add("my");
select.Select(AcSelect.acSelectionSetAll);
 Trying to modify this coede, but something is missing.
Tags (2)
3 REPLIES 3
BrentBurgess1980
I haven't got ACAD on this computer, so I can't verify the exactness of the code, but look at the editor and the PromptSelectionOptions and PromptSelctionResult
Hallex
If you using AcadInterop so try this code snip:
    AcadSelectionSet oSset = doc.SelectionSets.Add("my");
                //using filter
                object miss = Type.Missing;
                short[] dxfcode= new short[]{0};
                object[] dxfvalue= new object[]{"line,polyline,circle,ellipse,text,insert"};
                oSset.Select(AcSelect.acSelectionSetAll, miss, miss, dxfcode as object, dxfvalue as object);
                //send  message to command line:
                doc.Utility.Prompt(string.Format("\nSelected: {0} objects", oSset.Count));
~'J'~
amitnkukanur
But i am using Standard EXE and how does select all work in  my case and get the texts with Origins
Senior Software Engineer
”Boost
