.NET
Searching for text
11 REPLIES 11
Message 1 of 12
685 Views, 11 Replies
Searching for text
This question may be to broad or general. I don't know but here it goes anyway....
Is there a way to search for a specific text string on a layer in autocad?
Any help or a point in the right direction would be appreciated!!
11 REPLIES 11
Message 2 of 12
string ln = "layerName";
if (ln.Contains("stringToFind"))
wrote in message news:5264527@discussion.autodesk.com...
anyway....
Message 3 of 12
Thanks for the response but it just doesn't seem to be working.
I've tried several different things.
I'm currently getting the current layer:
Dim lt As LayerTable = CType(trans.GetObject(db.LayerTableId, OpenMode.ForRead), LayerTable)
Dim ltr As LayerTableRecord = CType(trans.GetObject(db.Clayer, OpenMode.ForRead), LayerTableRecord)
If ltr.Name.Contains("TheStringToFind") Then
MsgBox("Found It!!")
End IF
This doesn't work.
I've also tried:
Dim ln AS String = "CurrentLayer"
If ln.Contains("TheStringToFind") Then
That doesn't seem to work either? Am I missing something, doing something wrong?
Thanks Again....a bunch!!
Message 4 of 12
I assume you're changing "TheStringToFind" to
the string you're looling for?
wrote in message news:5264752@discussion.autodesk.com...
End IF
This doesn't work.
I've also tried:
wrong?
Message 5 of 12
Yes, you would be right. I am changing "TheStringToFind".
Exactly what I am doing is checking the layer to see if a specific string already exist before placing it on the layer. I just haven't figured out a way to search or find text.
Message 6 of 12
>End If
This would only be True if "TheStringToFind"
was contained in "CurrentLayer"; which it is
not.
"Paul Richardson" wrote in message
news:5264838@discussion.autodesk.com...
End IF
This doesn't work.
I've also tried:
wrong?
Message 7 of 12
It's in c#, but should give you the idea.
Sample call:
SSFilter("Text", "Layer1", "bar");
[code]
public static void SSFilter(string entType,
string layerName, string txtToFind)
Editor ed = Autodesk.AutoCAD.ApplicationServices.
Application.DocumentManager.MdiActiveDocument.Editor;
Database db = HostApplicationServices.WorkingDatabase;
TypedValue[] filter = new TypedValue[2]
new TypedValue((int)DxfCode.Start, entType),
new TypedValue((int)DxfCode.LayerName, layerName)
SelectionFilter filterSS = new SelectionFilter(filter);
PromptSelectionResult psr = ed.SelectAll(filterSS);
if (psr.Status != PromptStatus.OK) return;
ObjectIdCollection idCol =
new ObjectIdCollection(psr.Value.GetObjectIds());
using (Transaction tr =
db.TransactionManager.StartTransaction())
foreach (ObjectId id in idCol)
DBText dbt = (DBText)tr.GetObject
(id, OpenMode.ForRead, false);
if (((String)dbt.TextString).Contains(txtToFind))
//rip it up.
[/code]
wrote in message news:5264843@discussion.autodesk.com...
Message 8 of 12
Wow was that ugly...Here's a txt file.
news:5265051@discussion.autodesk.com...
Sample call:
[code]
//rip it up.
[/code]
Message 9 of 12
There was no need, in the code I posted, for the
block({}) around the code after the if statement.
Note the return, don't confuse with:
if()
Here is that portion without the {}.
[/code]
//rip it up.
[/code]
news:5265057@discussion.autodesk.com...
Sample call:
[code]
//rip it up.
[/code]
wrot
Message 10 of 12
Thanks, I'm trying it now!!
I'll post back when I'm done to let you know how it goes.
Thanks again!
Message 11 of 12
That worked perfectly!!!
Thanks a lot.......
Message 12 of 12
simon
I use this code to get text, you could identify the k string
If TypeOf entity Is Autodesk.AutoCAD.DatabaseServices.MText Then
TextBox1.Text += "*MTEXT FOUND " & vbCrLf
Dim Txt As Autodesk.AutoCAD.DatabaseServices.MText = entity
TxtFound = TxtFound + 1
Dim k
k = Txt.Contents
TextBox1.Text += "Contents " & k.ToString & vbCrLf & vbCrLf
TextFnd(1, TxtFound) = k.tostring
k = Txt.Location
TextBox1.Text += "Location " & k.ToString & vbCrLf
Dim Spl
Spl = Mid(k.tostring, 2, Len(k.tostring) - 2)
TextBox1.Text += "SPLIT" & Spl & vbCrLf
Dim sa() As String
sa = Split(Spl, ",", -1)
TextFnd(0, TxtFound) = TxtFound
TextFnd(2, TxtFound) = sa(0)
TextFnd(3, TxtFound) = sa(1)
”Boost
