.NET
Searching for text
11 REPLIES 11
Message 1 of 12
Natalie-C
679 Views, 11 Replies
Searching for text
This question may be to broad or general. I don't know but here it goes anyway....
Is there a way to search for a specific text string on a layer in autocad?
Any help or a point in the right direction would be appreciated!!
11 REPLIES 11
Message 2 of 12
in reply to: Natalie-C
string ln = "layerName";
if (ln.Contains("stringToFind"))
wrote in message news:5264527@discussion.autodesk.com...
anyway....
Message 3 of 12
Natalie-C
Thanks for the response but it just doesn't seem to be working.
I've tried several different things.
I'm currently getting the current layer:
Dim lt As LayerTable = CType(trans.GetObject(db.LayerTableId, OpenMode.ForRead), LayerTable)
Dim ltr As LayerTableRecord = CType(trans.GetObject(db.Clayer, OpenMode.ForRead), LayerTableRecord)
If ltr.Name.Contains("TheStringToFind") Then
MsgBox("Found It!!")
End IF
This doesn't work.
I've also tried:
Dim ln AS String = "CurrentLayer"
If ln.Contains("TheStringToFind") Then
End If
That doesn't seem to work either? Am I missing something, doing something wrong?
Thanks Again....a bunch!!
Message 4 of 12
I assume you're changing "TheStringToFind" to
the string you're looling for?
wrote in message news:5264752@discussion.autodesk.com...
End IF
This doesn't work.
I've also tried:
End If
wrong?
Message 5 of 12
Natalie-C
Yes, you would be right. I am changing "TheStringToFind".
Exactly what I am doing is checking the layer to see if a specific string already exist before placing it on the layer. I just haven't figured out a way to search or find text.
Message 6 of 12
>End If
This would only be True if "TheStringToFind"
was contained in "CurrentLayer"; which it is
not.
"Paul Richardson" wrote in message
news:5264838@discussion.autodesk.com...
End IF
This doesn't work.
I've also tried:
End If
wrong?
Message 7 of 12
It's in c#, but should give you the idea.
Sample call:
SSFilter("Text", "Layer1", "bar");
[code]
public static void SSFilter(string entType,
string layerName, string txtToFind)
Editor ed = Autodesk.AutoCAD.ApplicationServices.
Application.DocumentManager.MdiActiveDocument.Editor;
Database db = HostApplicationServices.WorkingDatabase;
TypedValue[] filter = new TypedValue[2]
new TypedValue((int)DxfCode.Start, entType),
new TypedValue((int)DxfCode.LayerName, layerName)
SelectionFilter filterSS = new SelectionFilter(filter);
PromptSelectionResult psr = ed.SelectAll(filterSS);
if (psr.Status != PromptStatus.OK) return;
ObjectIdCollection idCol =
new ObjectIdCollection(psr.Value.GetObjectIds());
using (Transaction tr =
db.TransactionManager.StartTransaction())
foreach (ObjectId id in idCol)
DBText dbt = (DBText)tr.GetObject
(id, OpenMode.ForRead, false);
if (((String)dbt.TextString).Contains(txtToFind))
//rip it up.
[/code]
wrote in message news:5264843@discussion.autodesk.com...
Message 8 of 12
Wow was that ugly...Here's a txt file.
news:5265051@discussion.autodesk.com...
Sample call:
[code]
//rip it up.
[/code]
Message 9 of 12
There was no need, in the code I posted, for the
block({}) around the code after the if statement.
Note the return, don't confuse with:
if()
Here is that portion without the {}.
[/code]
//rip it up.
[/code]
news:5265057@discussion.autodesk.com...
Sample call:
[code]
//rip it up.
[/code]
wrot
Message 10 of 12
Natalie-C
Thanks, I'm trying it now!!
I'll post back when I'm done to let you know how it goes.
Thanks again!
Message 11 of 12
Natalie-C
That worked perfectly!!!
Thanks a lot.......
Message 12 of 12
simon
I use this code to get text, you could identify the k string
If TypeOf entity Is Autodesk.AutoCAD.DatabaseServices.MText Then
TextBox1.Text += "*MTEXT FOUND " & vbCrLf
Dim Txt As Autodesk.AutoCAD.DatabaseServices.MText = entity
TxtFound = TxtFound + 1
Dim k
k = Txt.Contents
TextBox1.Text += "Contents " & k.ToString & vbCrLf & vbCrLf
TextFnd(1, TxtFound) = k.tostring
k = Txt.Location
TextBox1.Text += "Location " & k.ToString & vbCrLf
Dim Spl
Spl = Mid(k.tostring, 2, Len(k.tostring) - 2)
TextBox1.Text += "SPLIT" & Spl & vbCrLf
Dim sa() As String
sa = Split(Spl, ",", -1)
TextFnd(0, TxtFound) = TxtFound
TextFnd(2, TxtFound) = sa(0)
TextFnd(3, TxtFound) = sa(1)
End If
”Boost
