.NET
Active Member
Danius87
Message 1 of 3 (202 Views)
Search block by name
202 Views, 2 Replies
07-31-2012 06:04 AM
Hi at all, my name is Daniele.
I started to develop autocad's application with .Net framework.
But i have some trouble, particularly when i try to find a block by name (not like id).
I would take a block by name, instead to get all block and find one with comparison.
How can resolve this problem?
Thank's very much, and sorry for my bad english
Daniele
Try this code, not seriously tested though
This will select all blocks by name on the current layout
 [CommandMethod("AllBlockByName","abb", CommandFlags.Modal)]
public void GetAllBlockRefsByName()
Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed = doc.Editor;
ObjectIdCollection objIds = new ObjectIdCollection();
string ctab = Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("ctab").ToString();
string blockname = ed.GetString("\nEnter a block name: ").StringResult;
using (Transaction tr = db.TransactionManager.StartTransaction())
string bname = string.Concat( blockname,",*`U*");
TypedValue[] tvs = new TypedValue[] {
new TypedValue(-4, "<and"),
new TypedValue(0, "insert"),
new TypedValue(2, bname),
new TypedValue(410, ctab),
new TypedValue(-4, "and>")
SelectionFilter sf = new SelectionFilter(tvs);
PromptSelectionResult psr = ed.SelectAll(sf);
if (psr.Status != PromptStatus.OK)
ed.WriteMessage("\nWrong selection\n");
return;
ed.WriteMessage("\nCount of selected block: {0}", psr.Value.Count);
BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
BlockTableRecord btrec = null;
string brefname= "";
foreach (SelectedObject selobj in psr.Value)
DBObject obj = (DBObject)tr.GetObject(selobj.ObjectId, OpenMode.ForRead,false) ;
BlockReference bref = obj as BlockReference;
if (bref == null) continue;
if (!bref.IsDynamicBlock)
brefname = bref.Name;
else
btrec = (BlockTableRecord)tr.GetObject(bref.DynamicBlockTableRecord, OpenMode.ForRead, false, true);
brefname = btrec.Name;
if (brefname.CompareTo(blockname) == 0)
objIds.Add(bref.ObjectId);
for (int n=0;n< objIds.Count;n++)
DBObject ent = (DBObject)tr.GetObject(objIds[n], OpenMode.ForRead, false);
BlockReference btref = ent as BlockReference;
ed.WriteMessage("\nPosition: {0}\n", btref.Position);
// [ do your rest work with block instances here ] //
tr.Commit();
 Here is better explained article thanks to Stephen Preston:
http://adndevblog.typepad.com/autocad/2012/06/finding-all-block-references-of-a-dynamic-block.html
~'J'~
Hallex
Message 2 of 3 (184 Views)
Re: Search block by name
07-31-2012 08:26 AM in reply to: Danius87
                    return;
                    else
                tr.Commit();
~'J'~
Valued Mentor
fieldguy
Message 3 of 3 (183 Views)
07-31-2012 08:27 AM in reply to: Danius87
Hi Daniele - welcome aboard!
Please use the search tool 1st - this question is very common.  Enter your subject as is and start reading.
