.NET
Scrollbars in custom toolpalette
8 REPLIES 8
Message 1 of 9
956 Views, 8 Replies
I've created a custom toolpaletteset based on a user control named uc_Gewicht, however I don't know/can't access the scrollbars?
Imports System.Runtime
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.Internal
Public Class cls_Commando
    Friend Shared m_ps As Autodesk.AutoCAD.Windows.PaletteSet = Nothing
    <CommandMethod("MASSABEPALING")> Public Sub MassaBepaling()
        If m_ps = Nothing Then
            m_ps = New Autodesk.AutoCAD.Windows.PaletteSet("Massabepaling MM")
            m_ps.Add("Massabepaling MM", New uc_Gewicht)
        End If
        m_ps.Visible = True
    End Sub
End Class
 Regards
Peter
8 REPLIES 8
Message 2 of 9
arcticad
I don't think there are scroll bars in a palette.
Add your controls into a panel and then add the panel to palette.
Set your anchor points
Then set Panel's AutoScroll to true.
(defun botsbuildbots() (botsbuildbots))
Message 3 of 9
in reply to: arcticad
Thanks for your reply, now I get the vertical scrollbars. At the moment I haven't got the horizontal scrollbars. But I think I can manage to get them now.
Thanks!
Message 4 of 9
andre_adc-dao
I think I don't understand how to do that. I add a panel in my user control and put all my controls in that panel. I adjust the Autoscroll property to True on my panel but I don't see any difference.
I know you write "Add you controls into a panel and add the panel to palette" but I don't know how to create a panel and attach a user control by code  (maybe I have to create a user form???) and add it to the palette???? actually I add my userControl.
And what are the anchor points???
Do you have code sample?
André
Message 5 of 9
Step 1.
Create a User Control that you want.
Step 2.
Create a User Control that wraps the Control made in step 1.
You kan add it with the handler mybase.load
Private Sub uc_Step_2_load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
	Me.Controls.Add(New uc_Step_1)
End Sub
 In command you will create a palleteset to uc_Step_2 (the wrapper), make sure you've set the AutoScroll to True.
    <CommandMethod("MYPS")> Public Sub MYPS()
            m_ps = New Autodesk.AutoCAD.Windows.PaletteSet("My Custom PS")
            m_ps.KeepFocus = True
            m_ps.Add("My Custom PS", New uc_Step_2)
        End If
        m_ps.Visible = True
    End Sub
End Class
Regards
Peter
Message 6 of 9
arcticad
 myPanel.Anchor = CType(Windows.Forms.AnchorStyles.Bottom + _
                                         Windows.Forms.AnchorStyles.Left + _
                                         Windows.Forms.AnchorStyles.Right + _
                                         Windows.Forms.AnchorStyles.Top, Windows.Forms.AnchorStyles)
Message 7 of 9
Except that you don't use the addition (+) operator, you use the bitwise Or operator.
Message 8 of 9
andre_adc-dao
Sorry guys,
I'm not able to figure it. The only way I found to have a scrolling bar is to set the AutoScroll property of the control itself to True. But it doesn't work as AutoCAD native palette, the scrolling bar is at the right and doesn't have the same appearance.
I attached a project sample. I add directly the user control to the user control wrapper inside a panel but each time I run the project, I had to change manually the reference to my user control, After loading the project hou have to type ShowTestPalette.
If you can help.
Regards
André
Message 9 of 9
arcticad
in reply to: andre_adc-dao
here you go.
And strangly + works, but you should use OR.
if you dock the panel you don't need to worry about it anyways.
”Boost
