jensv:
I'm not familiar with scriptpro however,
Here is some .net code to do what you ask.
{code}
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Runtime
Public Class dxfout
Sub dxfOut()
Dim targetDirectory As String = "c:\myFiles\"
Dim OutputDirectory As String = "c:\myFiles\output\"
Dim fileEntries As String() = System.IO.Directory.GetFiles(targetDirectory)
If fileEntries.Count > 0 Then
If (Not System.IO.Directory.Exists(OutputDirectory)) Then
System.IO.Directory.CreateDirectory(OutputDirectory)
For Each fileName In fileEntries
If Not isFileInUse(fileName) Then
If fileName.Substring(fileName.Length - 3).ToUpper = "DWG" Then
Using db As New Autodesk.AutoCAD.DatabaseServices.Database(False, True)
Using tr As Transaction = db.TransactionManager.StartTransaction()
If getDatabase(fileName, db) Then
Dim outNewDXF As String = OutputDirectory & System.IO.Path.GetFileNameWithoutExtension(fileName) & ".dxf"
Try
db.DxfOut(outNewDXF, 8, True)
Catch ex As System.Exception
MsgBox("error writing: " * outNewDXF)
End Try
db.CloseInput(True)
End Using
End Using
Next
End Sub
Function getDatabase(ByVal FileName As String, ByRef db As Autodesk.AutoCAD.DatabaseServices.Database) As Boolean
Try
' Read File
db.ReadDwgFile(FileName, System.IO.FileShare.Read, True, "")
Return True
Return False
End Try
End Function
Public Function isFileInUse(ByVal sFile As String) As Boolean
If System.IO.File.Exists(sFile) Then
Try
Dim F As Short = FreeFile()
FileOpen(F, sFile, Microsoft.VisualBasic.OpenMode.Binary, OpenAccess.ReadWrite, OpenShare.LockReadWrite)
FileClose(F)
Catch
Return True
End Try
End Function
End Class
{code}
(defun botsbuildbots() (botsbuildbots))
