.NET
Giri_kani
Message 1 of 4 (171 Views)
Scaling Multiple Objects in .Net
171 Views, 3 Replies
03-28-2014 10:29 PM
I have a objectid collection, I need to scale all tha objects as the scale factor 20.
The object id collection have line,text,block and so on.
How to scale those objects using .net?
Please guide me.
Try this example borrowed from Jeff_H
 ''borrowed from Jeff_H
<CommandMethod("Sc20", CommandFlags.UsePickSet And CommandFlags.Redraw)> _
Public Shared Sub ScaleObjects()
Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
Dim ed As Editor = doc.Editor
Dim db As Database = doc.Database
Dim ppo As New PromptPointOptions("")
ppo.Message = vbLf & "Pick a center of scaling : "
ppo.AllowNone = False
Dim ppr As PromptPointResult
ppr = ed.GetPoint(ppo)
If ppr.Status <> PromptStatus.OK Then
Return
End If
Dim pc As Point3d = ppr.Value
Try
Using doclock As DocumentLock = doc.LockDocument()
Using tr As Transaction = doc.TransactionManager.StartTransaction()
Dim btr As BlockTableRecord = CType(tr.GetObject(db.CurrentSpaceId, OpenMode.ForRead), BlockTableRecord)
Dim pso As New PromptSelectionOptions
pso.MessageForRemoval = vbLf & "Nothing sdelected, try again."
pso.MessageForAdding = vbLf & "Select Objects to scale: "
pso.RejectObjectsOnLockedLayers = True
pso.RejectObjectsFromNonCurrentSpace = True
Dim res As PromptSelectionResult = ed.GetSelection(pso)
If res.Status <> PromptStatus.OK Then Return
Dim idArr() As ObjectId = res.Value.GetObjectIds()
btr.UpgradeOpen()
Dim ids As ObjectIdCollection = New ObjectIdCollection
For Each id As ObjectId In idArr
ids.Add(id)
Next
For Each id In ids
Dim ent As Entity = TryCast(tr.GetObject(id, OpenMode.ForRead, False), Entity)
If ent Is Nothing Then Return
If Not ent.IsWriteEnabled Then ent.UpgradeOpen()
ent.TransformBy(Matrix3d.Scaling(20.0, pc))
Next
tr.Commit()
End Using
End Using
Catch ex As Autodesk.AutoCAD.Runtime.Exception
Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(ex.Message & vbLf & ex.StackTrace)
Finally
End Try
End Sub
Valued Contributor
cdinten
Message 2 of 4 (147 Views)
Re: Scaling Multiple Objects in .Net
03-29-2014 12:25 AM in reply to: Giri_kani
using Entity.TransformBy() method, all you have to do is constructing a transform matrix that dealing with scaling
Hallex
Message 3 of 4 (149 Views)
03-29-2014 12:33 AM in reply to: Giri_kani
                Return
            End If
            Try
                        btr.UpgradeOpen()
                            ids.Add(id)
                        Next
                        For Each id In ids
                        Next
                        tr.Commit()
                    End Using
                End Using
            Finally
            End Try
        End Sub
Giri_kani
Message 4 of 4 (99 Views)
04-02-2014 12:48 AM in reply to: Hallex
This is working fine..
Thank you so much..
