.NET
Scaling Block Attributes
3 REPLIES 3
Amremad
660 Views, 3 Replies
Hello every body
How can i scale a block have some attributes , with known factor ?
3 REPLIES 3
jaboone
in reply to: Amremad
(setq oldortho (getvar "orthomode"))
(setq oldcanno (getvar "cannoscalevalue"))
I have a lisp routine for finding scale of a drawing.  Search the cannoscalevalue to find drawing scale and do your required math from there.
Hope this helps.
Learning as I go
Amremad
in reply to: jaboone
no i mean scalling using .net code
_gile
Did you try the Entity.TransformBy(Matrix3d.Scaling(scale, center)) method ?
Gilles Chanteau
GileCAD
GitHub
”Boost
