.NET
Valued Contributor
RamanSBV
Message 1 of 4 (298 Views)
Saving current drawing file.
298 Views, 3 Replies
08-21-2012 09:59 PM
Please help me on.. How to save current drawing file using save method.
Raman
http://www.theswamp.org/index.php?topic=42016.msg471429#msg471429
It is nice as in link to make it an extension method so you can just use Document.Save().
_gile
Message 2 of 4 (274 Views)
Re : Saving current drawing file.
08-22-2012 07:53 AM in reply to: RamanSBV
Did you look at: AutoCAD .NET Devemopper's Guide > Control the AutoCAD environment > Create, Open, Save and Close drawings > Create and Close a drawing ?
Gilles Chanteau
chiefbraincloud
Message 3 of 4 (273 Views)
Re: Saving current drawing file.
08-22-2012 07:55 AM in reply to: RamanSBV
The Database.Save method is "Not Implemented" at least through 2012.  It still says the same thing in the 2013 docs.
You have to use SaveAs, or if the drawing is open in the editor, and you are closing it after, I believe the Document.CloseAndSave method does work.  I just searched, and can't find any of my code that uses it, but I think it used it once in the past, but eventually changed that code to work on side databases instead of opening files into the editor.
Valued Mentor
jeff
Message 4 of 4 (263 Views)
08-22-2012 01:45 PM in reply to: RamanSBV
You can also find your answers @ TheSwamp
