.NET
Valued Contributor
RamanSBV
Message 1 of 11 (353 Views)
Saving active drawing file.
353 Views, 10 Replies
05-17-2012 11:13 PM
Could please any body give the suggestion on how to save active drawing file with filename..
Raman
BrentBurgess1980
Message 2 of 11 (350 Views)
Re: Saving active drawing file.
05-17-2012 11:35 PM in reply to: RamanSBV
Take a look at the Database.SaveAs Method.
Using AcApp = Autodesk.AutoCAD.ApplicationServices.Application;
//Inside your function
AcApp.DocumentManager.MdiActiveDocument.Database.SaveAs();
Valued Contributor
RamanSBV
Message 3 of 11 (348 Views)
05-17-2012 11:36 PM in reply to: BrentBurgess1980
Thanks for your post
Please suggest me, how i can give the file name for un saved file.
Raman
Alfred.NESWADBA
Message 4 of 11 (347 Views)
05-17-2012 11:38 PM in reply to: RamanSBV
if you want just to save a drawing:
  ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database.Save
In this case you should first compare it the file already has an assigned name!
If you want to give the file a new name the use:
  Dim tFilename as String = "C:\TEMP\XX.DWG"
  Dim tVersion as DatabaseServices.DwgVersion = DatabaseServices.DwgVersion.Current
  ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database.SaveAs(tFileName,tVersion)
In this case yo should first check that the file does not exist before you start save!
...assuming you have these Import-settings on top of your file:
Imports Autodesk.AutoCAD
HTH, - alfred -
Alfred NESWADBA
Valued Contributor
RamanSBV
Message 5 of 11 (342 Views)
05-18-2012 12:15 AM in reply to: Alfred.NESWADBA
I am getting below error while saving autocad file with file name. Please help me on this.eRROR
Alfred.NESWADBA
Message 6 of 11 (340 Views)
05-18-2012 12:17 AM in reply to: RamanSBV
to be honest ... can you read the text on your screenshot within your post?
If so let me know what browser you are using.
- alfred -
Alfred NESWADBA
BrentBurgess1980
Message 7 of 11 (336 Views)
05-18-2012 12:24 AM in reply to: Alfred.NESWADBA
From what little I could make out of the screenshot, it looks like it was "eWasOpenForWrite". I could be mistaken though...
Valued Contributor
RamanSBV
Message 8 of 11 (332 Views)
05-18-2012 12:29 AM in reply to: Alfred.NESWADBA
BrentBurgess1980
Message 9 of 11 (328 Views)
05-18-2012 12:38 AM in reply to: RamanSBV
You might need to lry locking the document
using (DocumentLock dLock = AcApp.DocumentManager.MdiActiveDocument.LockDocument())
                string tFilename = @"C:\TEMP\XX.DWG";
                Autodesk.AutoCAD.DatabaseServices.DwgVersion tVersion = Autodesk.AutoCAD.DatabaseServices.DwgVersion.Current;
                AcApp.DocumentManager.MdiActiveDocument.Database.SaveAs(tFilename, tVersion);
Alfred.NESWADBA
Message 10 of 11 (326 Views)
05-18-2012 12:42 AM in reply to: RamanSBV
have you installed the latest servicepacks? Did you run any code before you try to save and does this error also occure if yo udefine a command just doing that save?
To the error itself: it may not be a coding-fault as >>>this search<<< shows multiple appearances of this message.
- alfred -
Alfred NESWADBA
