.NET
SaveFileDialog & Last Directory
18 REPLIES 18
Message 1 of 19
Ron_M
7247 Views, 18 Replies
I'm having an issue with the SaveFileDialog always returning to the .dll working path instead of the last path saved to.  I know that the 4th argument sets this but after trying for several days to come up with the correct setting and failing to succeed I come to the Forum for assistance.  My code below:
    Public Sub SaveDrawing()
        Dim acDocMgr As DocumentCollection = Application.DocumentManager
        Dim SFD As New SaveFileDialog("", "", "dwg", "", Autodesk.AutoCAD.Windows.SaveFileDialog.SaveFileDialogFlags.AllowAnyExtension)
        If SFD.ShowDialog() = System.Windows.Forms.DialogResult.OK Then
            strName = Path.GetFileNameWithoutExtension(SFD.Filename)
            strPath = Path.GetDirectoryName(SFD.Filename)
            DFN = strPath + "\" + strName + ".dwg"
            DFP = strPath + "\"
        Else : Crash()
        End If
    End Sub
It would seem that I need somethig along the lines of System.IO.Path but I can't seem to get that to work.  I had thought the default was to the last saved path but that isn't how this is working.
18 REPLIES 18
Message 2 of 19
SENL1362
in reply to: Ron_M
I don't have a working .net sample with me but from my tips and trick file this c# sample may help:
C#/Microsoft/FileOpen/Desktop/OpenFileDialog/Common/SaveFile/FileSave
using Microsoft.Win32;
//Microsoft.Win32.SaveFileDialog dlg = new Microsoft.Win32.SaveFileDialog();
OpenFileDialog ofDlg = new OpenFileDialog();
ofDlg.InitialDirectory=Environment.GetFolderPath(Environment.SpecialFolder.DesktopDirectory);
ofDlg.FileName = "";
ofDlg.DefaultExt = ".dwg";
ofDlg.Filter = "Drawing (*.dwg)|*.dwg|DXF (*.dxf)|*.dxf|Drawing Template (*.dwt)|*.dwt|All Files (*.*)|*.*";
Nullable<bool> ofDlgRes = ofDlg.ShowDialog();
if (ofDlgRes != true)
return;
string dwgPathname = ofDlg.FileName;
Message 3 of 19
SENL1362
in reply to: Ron_M
May be the RestoreDirectory may have something to do with the return to that folder location
Dim saveFileDialog1 As New SaveFileDialog
saveFileDialog1.InitialDirectory = "C:\"
saveFileDialog1.Title = "Save text Files"
saveFileDialog1.CheckFileExists = True
saveFileDialog1.CheckPathExists = True
saveFileDialog1.DefaultExt = "txt"
saveFileDialog1.Filter = "Text files (*.txt)|*.txt|All files (*.*)|*.*"
saveFileDialog1.FilterIndex = 2
saveFileDialog1.RestoreDirectory = True
If (saveFileDialog1.ShowDialog() = DialogResult.OK) Then
TextBox1.Text = saveFileDialog1.FileName
End If
Message 4 of 19
khoa.ho
in reply to: SENL1362
RestoreDirectory is the property of System.Windows.Forms.SaveFileDialog. The AutoCAD class Autodesk.AutoCAD.Windows.SaveFileDialog does not have it. They are two different dialogs. AutoCAD Save Dialog has more items on the left to connect to FTP and Buzzaw while the normal Windows Save Dialog does not have.
In the following code snippet:
using SaveFileDialog = Autodesk.AutoCAD.Windows.SaveFileDialog;
SaveFileDialog SFD = new SaveFileDialog("", "", "dwg", "",
	SaveFileDialog.SaveFileDialogFlags.AllowAnyExtension |
	SaveFileDialog.SaveFileDialogFlags.ForceDefaultFolder);
Whether I include SaveFileDialog.SaveFileDialogFlags.ForceDefaultFolder or not include it, AutoCAD still opens the AutoCAD working path instead of the last saved path. I also don't know how to set the last saved location using .NET API. But AutoCAD can do it with its native code.
Message 5 of 19
jeff
in reply to: khoa.ho
I believe all that info is in th registry
I think you can use UserConfigurationManager.OpenDialogSection method to get the IConfigurationSection that reads and writes information in the dialog section of the registry.
And I think for example in 2013 it is in registry at
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R19.0\ACAD-B001:409\Profiles\[CurrentProfileName\Dialogs\Save Drawing As
I would open regedit and save a drawing in a folder with a unique or uncommon name then the right click on upper level folder in regedit and export it to file.
I would open with a text editor then do a search for folder name and drawing and see where it all shows up  then  save drawing in different locations and confirm value updates in registry with each save.
You can also find your answers @ TheSwamp
Message 6 of 19
SENL1362
in reply to: jeff
This works for me, that is i can define the default foldername without hacking the registry
Results:
Command: TESTSAVEAS
--> FileDialog opens in c:\temp
--> Browse to d:\Apldata\AutoCAD
Selected dxf Pathname==D:\AplData\AutoCAD\test.dxf
Command: TESTSAVEAS
Selected dxf Pathname==C:\temp\test.dxf
[CommandMethod("TestSaveAs")]
public static void TestSaveAs()
    Document doc = Application.DocumentManager.MdiActiveDocument;
    Editor ed = doc.Editor;
    try
        //using AcWin = Autodesk.AutoCAD.Windows;
        AcWin.SaveFileDialog.SaveFileDialogFlags saveFlags = AcWin.SaveFileDialog.SaveFileDialogFlags.DoNotTransferRemoteFiles;
        saveFlags |= AcWin.SaveFileDialog.SaveFileDialogFlags.ForceDefaultFolder;
        string defaultDxfPathname = @"c:\temp\test.dxf";
        //or assign only the ParentFoldername as the default Folder to store the file in, e.g.
        // string defaultDxfPathname = @"c:\temp\";
        AcWin.SaveFileDialog selDxf = new AcWin.SaveFileDialog("Select DXF file", defaultDxfPathname, "dxf", "TestSaveAs", saveFlags);
        System.Windows.Forms.DialogResult dlgRes = selDxf.ShowDialog();
        if (dlgRes != System.Windows.Forms.DialogResult.OK)
            return;
        string dxfPathname = selDxf.Filename;
        ed.WriteMessage("\n Selected dxf Pathname=={0}", dxfPathname);
    catch (System.Exception ex)
        ed.WriteMessage("\n {0}", ex.Message);
Message 7 of 19
SENL1362
This is another sample found and used a few years ago.
File Select Dialog opend from within a Form and using ED to prevent flashing the screen
private void SelectFile_Click(object sender, EventArgs e)
Document doc = Acad.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
using (EditorUserInteraction preventFlikkering = ed.StartUserInteraction(this))
PromptOpenFileOptions selGenDxf = new PromptOpenFileOptions("Select DXF");
selGenDxf.DialogCaption = "Select GEN dxf";
selGenDxf.InitialDirectory = @"C:\Apldata\AutoCAD\Smallworld_LS";
selGenDxf.Filter = "DXF File|*.dxf|AutoCAD File|*.dwg";
PromptFileNameResult selRes = ed.GetFileNameForOpen(selGenDxf);
if (selRes.Status != PromptStatus.OK) return;
this.tbFilename.Text = selRes.StringResult;
ed.WriteMessage("\nUser Selected: {0}", selRes.StringResult);
ed.Regen();
preventFlikkering.End();
Message 8 of 19
jeff
SENL1362,
The OP is wanting the dialog to open to the location of previous succuessful save. The registry is where AutoCAD saves that information and can be acessed between sessions.
Without "hacking the registry" can your make your example produce the following results
Command: TESTSAVEAS
CLOSE AUTOCAD
RESTART AUTOCAD
Command: TESTSAVEAS
--> FileDialog opens in D:\AplData\AutoCAD
--> Browse to C:\temp\New Folder
Selected dxf Pathname==C:\temp\New Folder\test.dxf
CLOSE AUTOCAD
RESTART AUTOCAD
Command: TESTSAVEAS
--> FileDialog opens in C:\temp\New Folder
Message 9 of 19
SENL1362
in reply to: jeff
Sure:
string lastOpenPathname = AcadConfigTools.Settings.Section["General"]["LastOpenLocation"];
lastOpenPathname=Path.GetDirectoryName(selectedLocation);
AcadConfigTools.Settings.Section["General"]["LastOpenLocation"]=lastOpenPathname ;
The AcadConfigTools.Settings is the integration of this INI file handling:
http://www.codeproject.com/Articles/318783/Simplified-INI-Handling
For read only ini file handling this is a really nice tool:
http://michael.chanceyjr.com/useful-code/ini-file-processing/
For the usage of the AutoCAD Dialogs,have a look at this article as well
http://through-the-interface.typepad.com/through_the_interface/2007/08/using-autocads-.html
Look for the comments on the fourth argument, it is a kind of automated hacking of the registry 🙂
Message 10 of 19
Ron_M
What would be the Import on AcadConfigTools?  Or if possible help me integrate into my posted code?
Message 11 of 19
SENL1362
in reply to: Ron_M
AcadConfigTools are custom made specialised tools which will be useless to you. I wrote it in te previous mail to Jeff to show him an alternative to registry manipulations.
To get back to you're problem, what did you specify as the 4th argument in the initial post?
Message 12 of 19
Ron_M
For the fourth aurgument I used "" which according to what I've been able to find is default and should return the last successful save path.
Message 13 of 19
SENL1362
in reply to: Ron_M
I doubt that. I think you have to specify a string constant, which will be the registry entry in which the settings of you're call will be saved.
The next time you call the dialog with the same string constant it will load and use the previous settings from that registry entry.
see "ExcelFileToLink" in this blog
Message 14 of 19
Ron_M
Thank you for your assistance.  I've previously looked at Kean's blog at that very entry and others on this subject and have found it to be of no help.  I'll continue to research this topic.
Message 15 of 19
SENL1362
in reply to: Ron_M
do you have access to the registry?
if so have a look at the location mentioned by Jeff.
Message 16 of 19
Ron_M
Resolved.  A lot easier than we thought.  Instead of using what Autodesk gives us I just used Net to create a registry key to store the last path to and then pull that in.  You'll notice that the last folder isn't the 4th argument, it's the second.
        Dim LastSave As String = My.Computer.Registry.GetValue("HKEY_CURRENT_USER\Software\Autodesk\Autocad\R19.1\ACAD-D004:409\Forum-2014\", "LastSave", Nothing)
        Dim SFD As New Autodesk.AutoCAD.Windows.SaveFileDialog("", LastSave, "dwg", "", Autodesk.AutoCAD.Windows.SaveFileDialog.SaveFileDialogFlags.AllowAnyExtension)
            DFP = strPath + "\"
            My.Computer.Registry.SetValue("HKEY_CURRENT_USER\Software\Autodesk\Autocad\R19.1\ACAD-D004:409\Forum-2014\", "LastSave", DFP)
        Else : Crash()
        End If
    End Sub
Message 17 of 19
SENL1362
in reply to: Ron_M
Then credits to Jeff, it was his idea: Kudos++;
Thank you Ron for posting you're solution.
Message 18 of 19
Mendo123
in reply to: Ron_M
Hi, (newbie question)
Does anyone know how to filter revits ".rvt" files in the savefiledialog? everything I try throws an error.
I have no experience with the Filter property.
            string mydocumentsPath = Environment.GetFolderPath(Environment.SpecialFolder.MyDocuments);
            string myDocumentSavedFilename = doc.Title + ".rvt";
            string myDocumentsFullPath = Path.Combine(mydocumentsPath, myDocumentSavedFilename);
            SaveFileDialog saveFileDialog1 = new SaveFileDialog();
            saveFileDialog1.Title = "Save project";
            saveFileDialog1.Filter = ?????
saveFileDialog1.InitialDirectory = myDocumentsFullPath; saveFileDialog1.DefaultExt = ".rvt"; saveFileDialog1.FileName = myDocumentsFullPath;
Thank you in advance
Message 19 of 19
SENL1362
in reply to: Mendo123
”Boost
