.NET
SaveAs problem in AC2007
3 REPLIES 3
bowa
360 Views, 3 Replies
I'm trying to save my AutoCAD drawing using the SaveAs function in AutoCAD 2007 and VS2005.
In AutoCAD 2006 and VB2003 I used:
strFile = Dwg.FullName.ToString()
Dim acadSaveAsType As Object = Dwg.AcSaveAsType.acR18_dwg
Dwg.SaveAs(strFile, acadSaveAsType, Autodesk.AutoCAD.DatabaseServices.SecurityParameters)
This worked without issue but now I'm getting and error indicating that the SecurityParameters are a type and not an object.
Can anyone tell me what object I should be using?
3 REPLIES 3
in reply to: bowa
Firstly you are using the ActiveX API not the .NET API.
It should never have worked because as the error indicates you are trying to pass the SecurityParameters type instead of an instance. Given it is an optional value you can leave it out all together.
Dwg.SaveAs(strFile, acR18_dwg)
Regards - Nathan
in reply to: bowa
What you show never worked, at least not as it
was posted.
You're confusing a type, with an instance of a
type. You're passing a type as the security params,
not an instance of the type.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2008
Supporting AutoCAD 2000 through 2008
http://www.acadxtabs.com
wrote in message news:5612704@discussion.autodesk.com...
jbooth
in reply to: bowa
As already stated in previous replies, you are trying to pass a class definition into a function that is expecting an object reference.
You can fix it by creating a new instance of the AcDb.SecurityParameters class and pass that into your saveas function.
However, note that the AcadDocument.SaveAs() function has only one required parameter. The other two are optional.
Calling Dwg.SaveAs(strFile) should work in the general case, as it saves in the current version, and uses the default security parameters.
”Boost
