.NET
Valued Contributor
GrzesiekGP
Message 1 of 20 (827 Views)
Accepted Solution
Save some variables into DWG file - how? C#.
827 Views, 19 Replies
09-12-2012 10:13 AM
Hello!
Please let me know if I'm able to save some variables into current DWG?
I would like to provide availability for user to save some data which is different for each DWG file.
Thanks.
*Expert Elite*
arcticad
Message 2 of 20 (821 Views)
Re: Save some variables into DWG file - how? C#.
09-12-2012 10:47 AM in reply to: GrzesiekGP
Board Manager
StephenPreston
Message 3 of 20 (811 Views)
09-12-2012 11:52 AM in reply to: arcticad
Further to arcticad's reply, you'd typically store global data on the Named Objects Dictionary, and data related to a particular entity as xdata on that entity or as an xrecord in its extension dictionary.
But if you're storing 'variables' (sysvars), then you migh prefer to use the Autodesk.AutoCAD.Runtime.Variable class. You can specify whether the variable is per session, per user, per profile or per database.
Cheers,
Stephen Preston
Autodesk Developer Network
*Expert Elite*
arcticad
Message 4 of 20 (800 Views)
09-12-2012 01:17 PM in reply to: StephenPreston
I don't seem to find any information on how to use Autodesk.AutoCAD.Runtime.Variable
Can you point me in the direction.
Thanks.
(defun botsbuildbots() (botsbuildbots))
Active Contributor
RichardCammeray
Message 5 of 20 (786 Views)
09-12-2012 05:02 PM in reply to: GrzesiekGP
I used LispVariable to store data in file so user could use them in Text Field.
Here are examples how to get and set Lisp Variables I used.
http://www.theswamp.org/index.php?topic=35714.0
Richard.
Active Contributor
RichardCammeray
Message 6 of 20 (782 Views)
09-12-2012 05:22 PM in reply to: GrzesiekGP
I forgot to say then these variables are not saved in drawing.
Richard
Valued Contributor
GrzesiekGP
Message 7 of 20 (759 Views)
09-12-2012 10:28 PM in reply to: GrzesiekGP
Thank you for the links.
Following the first, I have question - am I able to set my XData without selecting an entity?
*Expert Elite*
_gile
Message 8 of 20 (757 Views)
09-12-2012 10:35 PM in reply to: arcticad
Hi articad,
You can see this thread about custom Variables.
IMO, the main issue with Autodesk.AutoCAD.Runtim.Variable is the variable has to be registered in HKLM which most often requires administrator user account.
Gilles Chanteau
Active Contributor
RichardCammeray
Message 9 of 20 (753 Views)
09-12-2012 10:41 PM in reply to: GrzesiekGP
Use DBDictionary to save data (XRecord) in file.
Try to search for   NamedObjectsDictionary (NOD) you should find many examples in this forum.
Richard
*Expert Elite*
_gile
Message 10 of 20 (749 Views)
09-12-2012 10:43 PM in reply to: GrzesiekGP
Hi GrzesiekGP,
If you want to go the Xdata route without selecting an entity, you can set your Xdata on any DBObject (i.e. layer "0", model space BlockTableRecord) but, IMO, you'd rather use a DBDictionary and Xrecord.
Gilles Chanteau
Announcements
Need installation help?
