.NET
.NET
Valued Contributor
1 Kudo
Post 1 of 20
Save some variables into DWG file - how? C#.
975 Views, 19 Replies
09-12-2012 10:13 AM
Hello!
Please let me know if I'm able to save some variables into current DWG?
I would like to provide availability for user to save some data which is different for each DWG file.
Thanks.
Here're two little example to set and get xrecord data (ResultBuffer as for Xdata) in a named dictionary child of the root NamedObjectsDictionary (NOD).
 /// <summary>
/// Add or edit a Xrecord data in a named dictionary (the dictionary and xrecord are created if not already exist)
/// </summary>
/// <param name="dictName">The dictionary name</param>
/// <param name="key">the xrecord key</param>
/// <param name="resbuf">the xrecord data</param>
public void SetXrecord(string dictName, string key, ResultBuffer resbuf)
Document doc = acadApp.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
using (Transaction tr = db.TransactionManager.StartTransaction())
DBDictionary NOD =
(DBDictionary)tr.GetObject(db.NamedObjectsDictionaryId, OpenMode.ForRead);
DBDictionary dict;
if (NOD.Contains(dictName))
dict = (DBDictionary)tr.GetObject(NOD.GetAt(dictName), OpenMode.ForWrite);
else
dict = new DBDictionary();
NOD.UpgradeOpen();
NOD.SetAt(dictName, dict);
tr.AddNewlyCreatedDBObject(dict, true);
Xrecord xRec = new Xrecord();
xRec.Data = resbuf;
dict.SetAt(key, xRec);
tr.AddNewlyCreatedDBObject(xRec, true);
tr.Commit();
/// <summary>
/// Gets an xrecord data in a named dictionary
/// </summary>
/// <param name="key">The xrecord key</param>
/// <returns>The xrecord data or null if the dictionary or the xrecord do not exist</returns>
public ResultBuffer GetXrecord(string dictName, string key)
DBDictionary NOD =
if (!NOD.Contains(dictName))
return null;
DBDictionary dict = tr.GetObject(NOD.GetAt(dictName), OpenMode.ForRead) as DBDictionary;
if (dict == null || !dict.Contains(key))
return null;
Xrecord xRec = tr.GetObject(dict.GetAt(key), OpenMode.ForRead) as Xrecord;
if (xRec == null)
return null;
return xRec.Data;
As for Xdata you have to use a ResultBuffer to set data in a Xrecord and the Xrecord.Data property is a ResultBuffer.
Assuming your xrecord contains a single data of type String, you can get the data this way:
ResultBuffer resbuf = GetXrecord(theDictName, theXrecKey);
string theFirstData =(string) resbuf.AsArray()[0].Value;
It looks like you forgot to call: tr.Commit();
37 Kudos
Post 2 of 20
Re: Save some variables into DWG file - how? C#.
09-12-2012 10:47 AM in reply to: GrzesiekGP
ADN Support Specialist
67 Kudos
Post 3 of 20
09-12-2012 11:52 AM in reply to: arcticad
Further to arcticad's reply, you'd typically store global data on the Named Objects Dictionary, and data related to a particular entity as xdata on that entity or as an xrecord in its extension dictionary.
But if you're storing 'variables' (sysvars), then you migh prefer to use the Autodesk.AutoCAD.Runtime.Variable class. You can specify whether the variable is per session, per user, per profile or per database.
Cheers,
Stephen Preston
Autodesk Developer Network
37 Kudos
Post 4 of 20
09-12-2012 01:17 PM in reply to: StephenPreston
I don't seem to find any information on how to use Autodesk.AutoCAD.Runtime.Variable
Can you point me in the direction.
Thanks.
(defun botsbuildbots() (botsbuildbots))
Valued Contributor
5 Kudos
Post 5 of 20
09-12-2012 05:02 PM in reply to: GrzesiekGP
I used LispVariable to store data in file so user could use them in Text Field.
Here are examples how to get and set Lisp Variables I used.
http://www.theswamp.org/index.php?topic=35714.0
Richard.
Valued Contributor
5 Kudos
Post 6 of 20
09-12-2012 05:22 PM in reply to: GrzesiekGP
I forgot to say then these variables are not saved in drawing.
Richard
Valued Contributor
1 Kudo
Post 7 of 20
09-12-2012 10:28 PM in reply to: GrzesiekGP
Thank you for the links.
Following the first, I have question - am I able to set my XData without selecting an entity?
254 Kudos
Post 8 of 20
09-12-2012 10:35 PM in reply to: arcticad
Hi articad,
You can see this thread about custom Variables.
IMO, the main issue with Autodesk.AutoCAD.Runtim.Variable is the variable has to be registered in HKLM which most often requires administrator user account.
Gilles Chanteau
Valued Contributor
5 Kudos
Post 9 of 20
09-12-2012 10:41 PM in reply to: GrzesiekGP
Use DBDictionary to save data (XRecord) in file.
Try to search for   NamedObjectsDictionary (NOD) you should find many examples in this forum.
Richard
254 Kudos
Post 10 of 20
09-12-2012 10:43 PM in reply to: GrzesiekGP
Hi GrzesiekGP,
If you want to go the Xdata route without selecting an entity, you can set your Xdata on any DBObject (i.e. layer "0", model space BlockTableRecord) but, IMO, you'd rather use a DBDictionary and Xrecord.
Gilles Chanteau
