.NET
New Member
EvertM
Message 1 of 20 (942 Views)
Save preview to file
942 Views, 19 Replies
06-12-2005 12:34 PM
Hi all,
I try to save the thumbnail to a file, but it seems ThumbnailBitmap is alway's nothing. Does anyone know how to use this Autodesk.AutoCAD.DatabaseServices.Database.ThumbnailBitmap?
thanks,
Evert
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports System.Collections
Imports System.Text
Imports System.Drawing
Public Class PreviewBitMap
Public Sub test()
Dim bm As Bitmap
Dim db As Database
Try
'Get the current database
db = HostApplicationServices.WorkingDatabase
Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage("db loaded")
If db.ThumbnailBitmap Is Nothing Then
Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage("geen bitmap?")
Else
db.ThumbnailBitmap.Save("test.bmp")
End If
Catch ex As Exception
Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage("test:" + ex.Message)
Finally
If Not bm Is Nothing Then bm.Dispose()
End Try
End Sub
End Class
*Albert Szilvasy
Message 2 of 20 (942 Views)
Re: Save preview to file
06-12-2005 08:49 PM in reply to: EvertM
You can't set a thumbnail currently. I consider this a bug so I'll make sure
we have defect logged.
albert
wrote in message news:4872660@discussion.autodesk.com...
Hi all,
thanks,
Evert
Imports System.Text
Public Sub test()
Dim bm As Bitmap
Dim db As Database
Try
loaded")
bitmap?")
Else
End If
+ ex.Message)
Finally
End Try
End Sub
End Class
New Member
EvertM
Message 3 of 20 (942 Views)
06-22-2005 08:07 AM in reply to: EvertM
I reported this, but the thumbnail attribute has the status 'Not Implemented' (yet). It would be nice if autocad would throw an 'Not Implemented' error instead of just returning Nothing.
*Tony Tanzillo
Message 4 of 20 (942 Views)
06-22-2005 09:44 AM in reply to: EvertM
>> a bug so I'll make sure we have defect logged.
If the objective is getting the bitmap, as opposed to
setting it, the problem is most likely this (from the
docs for AcDbDatabase::thumbnailBitmap):
"Note These APIs are meant primarily for ObjectDBX developers.
Preview thumbnail behavior reflect what the host application must
do to generate a preview.
For ObjectARX developers AutoCAD is taking care of all preview
thumbnail generation. ObjectARX users should leave these APIs
alone, and allow AutoCAD behaviors to prevail.
Most of the time, the AcDbDatabase::thumbnailBitmap() method
will return nothing, since the bitmap is not read into memory by
AcDbDatabase::readDwgFile(). To retreive the thumbnail from the
DWG file, (as opposed to directly from the db) the same existing
ObjectARX standalone functions are preferred. (for example
acdbDisplayPreviewFromDwg())".
I haven't tried this, but it should work (please let me know
if it doesn't).
/////////////////// ThumbnailExtractor.cs ///////////////////////
using System;
using System.Drawing;
using System.Runtime.InteropServices;
using Autodesk.AutoCAD.Runtime;
namespace acdbUtils
public class ThumbnailExtractor
[System.Security.SuppressUnmanagedCodeSecurity]
[DllImport("acdb16.dll", CallingConvention = CallingConvention.Cdecl,
EntryPoint = "?acdbGetPreviewBitmap@@YAPAUtagBITMAPINFO@@PBD@Z")]
extern static private IntPtr acdbGetPreviewBitmap(string filename);
static Bitmap GetBitmapFromDwg(string filename)
return Marshaler.BitmapInfoToBitmap(acdbGetPreviewBitmap(filename));
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
Valued Contributor
aslam
Message 5 of 20 (942 Views)
07-26-2006 11:11 PM in reply to: EvertM
Sir ,
As you told i tried this code but it didn't work
using System;
namespace acdbUtils
Thanks....
Distinguished Contributor
Alexander Rivilis
Message 6 of 20 (942 Views)
08-31-2006 07:17 AM in reply to: EvertM
[code]
[DllImport("dwgpreview.arx", CallingConvention = CallingConvention.Cdecl, CharSet = CharSet.Ansi ,
EntryPoint = "SaveDWGPreview")]
extern static private int SaveDWGPreview(string dwgfilename, string bmpfilename);
[CommandMethod("SavePreview")]
public void SavePreview()
Database db = HostApplicationServices.WorkingDatabase;
Autodesk.AutoCAD.Runtime.SystemObjects.DynamicLinker.LoadModule("DWGPreview.arx",false,false);
SaveDWGPreview(db.Filename,"C:\\dwgpreview.bmp");
[/code]
dwgpreview.arx for AutoCAD 2004...2006 is attached Message was edited by: Alexander Rivilis
*Tony Tanzillo
Message 7 of 20 (942 Views)
08-31-2006 09:10 AM in reply to: EvertM
For AutoCAD 2007, this should do it:
/// Form1.cs
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Text;
using System.Windows.Forms;
using Autodesk.AutoCAD.ApplicationServices;
using AcadApp = Autodesk.AutoCAD.ApplicationServices.Application;
// This form requires a PictureBox named 'pictureBox1':
namespace ThumbnailSample
public partial class Form1 : Form
public Form1()
InitializeComponent();
// R17 ONLY
[DllImport( "acad.exe", CallingConvention = CallingConvention.Cdecl,
EntryPoint = "?acedGenerateThumbnailBitmap@@YAPAUtagABITMAPINFO@@XZ" )]
private static extern IntPtr acedGenerateThumbnailBitmap();
private void ThumbView_Load( object sender, EventArgs e )
IntPtr bmi = acedGenerateThumbnailBitmap();
if( bmi != IntPtr.Zero )
Bitmap bm = Marshaler.BitmapInfoToBitmap( bmi );
pictureBox1.Image = (System.Drawing.Image) bm.Clone();
bm.Dispose();
[CommandMethod( "THUMBVIEW" )]
public static void doit()
using( Form1 form = new Form1() )
AcadApp.ShowModalDialog( form );
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
wrote in message news:5313888@discussion.autodesk.com...
[code]
[/code]
Valued Contributor
aslam
Message 8 of 20 (942 Views)
09-03-2006 12:33 AM in reply to: EvertM
Sir,
Your code is working great. But i want to know does it not works for Autocad 2007 3D Drawings template(acad3D.dwt type files). If i want to save all types of autocad files's thumbanil then how can i achive this.
Thanks...
Valued Contributor
aslam
Message 9 of 20 (942 Views)
09-03-2006 08:29 PM in reply to: EvertM
Hi rivilis,
I want to know if you have got dwgpreview.arx for Autocad 2007. IF not then how can i do it in 2007. Tony's code is working but not for 3D drawings.
Thanks....
Alexander Rivilis
Message 10 of 20 (942 Views)
09-04-2006 02:35 AM in reply to: EvertM
Try it:
[code]
[DllImport("dwgpreview.arx", CallingConvention = CallingConvention.Cdecl, CharSet = CharSet.Unicode,
[/code]
