.NET
New Member
pk91
Message 1 of 2 (123 Views)
save generated autocad file
123 Views, 1 Replies
02-10-2006 04:53 AM
I'm making an application that starts up Autocad 2006 and generates a drawing and saves it to a dwg file in a specific by user chosen file format (2000 or 2006). I’m using C#.net, and have one comp running Autocad 2006 LT where the application runs on and an other comp running Autocad 2000 in the same network.
my question is if somebody can help me with the following function:
AcadDocument.SaveAs(string fullFileName, object SaveAsType, object vSecurityParms)
I don't know what they want for an obect at the SaveAsType and the vSecurityParams.
Member
detox
Message 2 of 2 (123 Views)
Re: save generated autocad file
02-26-2006 03:04 AM in reply to: pk91
ActiveDocument.SaveAs(@"C:\test.dwg",Application.Preferences.OpenSave.SaveAsType , null);
Autodesk Alert | We are currently working on restoring Previous Version License request access in the Autodesk Subscription Center. If you are a subscription customer and would like to request a Previous Version License, please use this link as a temporary workaround. We apologize for the inconvenience and thank you for your patience.
