.NET
.NET
0 Kudos
Post 1 of 14
Save, Close, and re-Open a Drawing
564 Views, 13 Replies
07-20-2012 08:22 AM
I would like to have a sub that gets the drawing name, saves it, closes the drawing, then re-opens it (because of a 2010 bug).
This is what I have, but from what I've read I need to have "commandflags.session" to work outside of the drawing.  How would I use it for this sub?  All I've seen is the commandflags.session included in the CommandMethod.
This code is in a sub, in a Module.  The only CommandMethod I have is the command I use to start the code in the "Class" module.  I tried putting it in that command, but it didn't work as it now had a problem with the layertable in another sub.
' This will save the current drawing, close the drawing, then re-open it
    Public Sub SaveCloseOpenDwg()
        Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
        Dim acDocMgr As DocumentCollection = Application.DocumentManager
        Dim strDWGName As String = acDoc.Name
        ' Save the active drawing
        acDoc.Database.SaveAs(strDWGName, True, DwgVersion.Current, acDoc.Database.SecurityParameters)
        acDocMgr.CloseAll()
        acDocMgr.Open(strDWGName, False)
    End Sub
 I run the program from a drawing rthat is currently open/active.  Is there a method that would let me save the current drawing, open a new drawing, close my original, then re-open the original and close the new drawing?  I know that sounds cludgy, but it's there's a bug in AutoCad 2010, that doesn't update the layermanger that I need to work around.  I found if I manually save the design, close and re-open it, the layer manager clears up.  This doesn't happen in AutoCad 2008 or 2012.
Mark
Valued Mentor
30 Kudos
Post 2 of 14
Re: Save, Close, and re-Open a Drawing
07-20-2012 09:21 AM in reply to: mgorecki
You could try something like message 5 >>here<
0 Kudos
Post 3 of 14
07-20-2012 10:27 AM in reply to: fieldguy
Thanks, I'll check it out.
0 Kudos
Post 4 of 14
07-20-2012 12:59 PM in reply to: fieldguy
Hi Fieldguy,
I'm not sure I fully understand your code.  it looks like it has an open/active drawing (drawing1) and it opens another drawing (drawing2 based on "map2diso.dwt")  It can do stuff then closes and discards drawing2.  Then it opens a third drawing, (drawing3 based on template "map2diso.dwt") does stuff and then closes/discards.  Has the original drawig1 been open all this time?  Is there a way to open the blank drawing2, close drawing1, then re-open drawing1 and close/discard drawing2?
Private Sub testsub(ByVal data As Object)
        'in this example data is not used
        Dim cmddiavalue As Integer = CInt(acapp.Application.GetSystemVariable("CMDDIA")?)
        acapp.Application.SetSystemVariable("CMDDIA", 0)
        Dim acdocmgr As acapp.DocumentCollection = acapp.Application.DocumentManager
        Dim acdoc As acapp.Document = acdocmgr.MdiActiveDocument <--Does this set the current drawing as acdoc?
        Dim templatepath As String = "map2diso.dwt"
        acdoc = acdocmgr.Add(templatepath) <--Adds "map2diso.dwt" to the document collection?
        acdocmgr.MdiActiveDocument = acdoc <--Makes "map2diso.dwt" the active document?  Is the original drawing still open?  If so, how do I close it?
        'drawing2 is now active
        Using acdoclock As acapp.DocumentLock = acdoc.LockDocument
            Dim currentobjs As New ObjectIdCollection()
            'query and save
        End Using
        acdoc.CloseAndDiscard() <--Closes the document "map2diso.dwt"?
        acdoc = acdocmgr.Add(templatepath) <--Not sure what drawing is being set as current here
        'drawing3
            'query and save
        End Using
        acapp.Application.SetSystemVariable("CMDDIA", cmddiavalue)
        Autodesk.AutoCAD.Internal.Utils.PostCommandPrompt(?)
        'return to drawing1 or whatever doc was before <--Being as drawing 1 was never closed, is it just made current again?
    End Sub
Mark
Valued Mentor
30 Kudos
Post 5 of 14
07-20-2012 01:16 PM in reply to: mgorecki
Hi Mark.  I should have tried this before I posted.  You are correct that the code creates new blank dwgs and saves them with the original drawing not touched in any way.  When the code is finished, the user is returned to the original dwg.  When I searched for information on "executeinapplicationcontext", there was a post from Tony T that warned against manipulating the doc that is active before that call.  It definitely generates a fatal exception if you try to close it - locked or not.  My guess is that acad has a lock on the dwg already and won't allow that level of access (ie. close).
I'll keep digging because I have a use for this as well, and there should be a way to do it.
0 Kudos
Post 6 of 14
07-20-2012 01:57 PM in reply to: mgorecki
In the "Class" module, I added Commandflags.Session:
<CommandMethod("ADP", CommandFlags.Session)> _
PublicSub ADP()
I'm trying to use it because I need to close the current/active drawing, but I then get an error with a layertable in a subsequent sub - see attached jpg.
What do I need to do in this instance?
171 Kudos
Post 7 of 14
07-20-2012 02:19 PM in reply to: mgorecki
    <CommandMethod("SaveCloseOpen", "sco", CommandFlags.Session)> _
        Dim acDoc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
        Dim acDocMgr As DocumentCollection = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager
        Using dcoclock As DocumentLock = acDoc.LockDocument()
            ''do your job here
        End Using
        acDocMgr.CloseAll()
    End Sub
I tested it on my A2010, Relese mode, see if this working on your end
~'J'~
0 Kudos
Post 8 of 14
07-20-2012 02:28 PM in reply to: Hallex
Hi Hallex,
Do you know if a program commandMethod can launch another commandMethod?
For example,
Public
<CommandMethod("ADP")> _
  PublicSub ADP()
   launch SaveCloseOpen
  End Sub
  End Sub
 Also, will this work if the program was launched inside the active drawing?
Valued Mentor
30 Kudos
Post 9 of 14
07-20-2012 02:36 PM in reply to: mgorecki
You have to lock the document before your layertable transaction.  Release the lock after you commit the transaction.
0 Kudos
Post 10 of 14
07-20-2012 02:50 PM in reply to: fieldguy
Ok, cool.  Thank you.
