I would like to have a sub that gets the drawing name, saves it, closes the drawing, then re-opens it (because of a 2010 bug).
This is what I have, but from what I've read I need to have "commandflags.session" to work outside of the drawing. How would I use it for this sub? All I've seen is the commandflags.session included in the CommandMethod.
This code is in a sub, in a Module. The only CommandMethod I have is the command I use to start the code in the "Class" module. I tried putting it in that command, but it didn't work as it now had a problem with the layertable in another sub.
' This will save the current drawing, close the drawing, then re-open it Public Sub SaveCloseOpenDwg() Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument Dim acDocMgr As DocumentCollection = Application.DocumentManager Dim strDWGName As String = acDoc.Name ' Save the active drawing acDoc.Database.SaveAs(strDWGName, True, DwgVersion.Current, acDoc.Database.SecurityParameters) acDocMgr.CloseAll() acDocMgr.Open(strDWGName, False) End Sub
I run the program from a drawing rthat is currently open/active. Is there a method that would let me save the current drawing, open a new drawing, close my original, then re-open the original and close the new drawing? I know that sounds cludgy, but it's there's a bug in AutoCad 2010, that doesn't update the layermanger that I need to work around. I found if I manually save the design, close and re-open it, the layer manager clears up. This doesn't happen in AutoCad 2008 or 2012.
Mark
Hi Fieldguy,
I'm not sure I fully understand your code. it looks like it has an open/active drawing (drawing1) and it opens another drawing (drawing2 based on "map2diso.dwt") It can do stuff then closes and discards drawing2. Then it opens a third drawing, (drawing3 based on template "map2diso.dwt") does stuff and then closes/discards. Has the original drawig1 been open all this time? Is there a way to open the blank drawing2, close drawing1, then re-open drawing1 and close/discard drawing2?
Private Sub testsub(ByVal data As Object)
'in this example data is not used
Dim cmddiavalue As Integer = CInt(acapp.Application.GetSystemVariable("CMDDIA")?)
acapp.Application.SetSystemVariable("CMDDIA", 0)
Dim acdocmgr As acapp.DocumentCollection = acapp.Application.DocumentManager
Dim acdoc As acapp.Document = acdocmgr.MdiActiveDocument <--Does this set the current drawing as acdoc?
Dim templatepath As String = "map2diso.dwt"
acdoc = acdocmgr.Add(templatepath) <--Adds "map2diso.dwt" to the document collection?
acdocmgr.MdiActiveDocument = acdoc <--Makes "map2diso.dwt" the active document? Is the original drawing still open? If so, how do I close it?
'drawing2 is now active
Using acdoclock As acapp.DocumentLock = acdoc.LockDocument
Dim currentobjs As New ObjectIdCollection()
'query and save
End Using
acdoc.CloseAndDiscard() <--Closes the document "map2diso.dwt"?
acdoc = acdocmgr.Add(templatepath) <--Not sure what drawing is being set as current here
'drawing3
'query and save
End Using
acapp.Application.SetSystemVariable("CMDDIA", cmddiavalue)
Autodesk.AutoCAD.Internal.Utils.PostCommandPrompt(?)
'return to drawing1 or whatever doc was before <--Being as drawing 1 was never closed, is it just made current again?
End Sub
Mark
Hi Mark. I should have tried this before I posted. You are correct that the code creates new blank dwgs and saves them with the original drawing not touched in any way. When the code is finished, the user is returned to the original dwg. When I searched for information on "executeinapplicationcontext", there was a post from Tony T that warned against manipulating the doc that is active before that call. It definitely generates a fatal exception if you try to close it - locked or not. My guess is that acad has a lock on the dwg already and won't allow that level of access (ie. close).
I'll keep digging because I have a use for this as well, and there should be a way to do it.
In the "Class" module, I added Commandflags.Session:
<CommandMethod("ADP", CommandFlags.Session)> _ PublicSub ADP()
I'm trying to use it because I need to close the current/active drawing, but I then get an error with a layertable in a subsequent sub - see attached jpg.
What do I need to do in this instance?
<CommandMethod("SaveCloseOpen", "sco", CommandFlags.Session)> _ Public Sub SaveCloseOpenDwg() Dim acDoc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument Dim acDocMgr As DocumentCollection = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager Dim strDWGName As String = acDoc.Name Using dcoclock As DocumentLock = acDoc.LockDocument() ''do your job here ' Save the active drawing acDoc.Database.SaveAs(strDWGName, True, DwgVersion.Current, acDoc.Database.SecurityParameters) End Using acDocMgr.CloseAll() acDocMgr.Open(strDWGName, False) End Sub
I tested it on my A2010, Relese mode, see if this working on your end
~'J'~
Hi Hallex,
Do you know if a program commandMethod can launch another commandMethod?
For example,
Public
<CommandMethod("ADP")> _
PublicSub ADP()
launch SaveCloseOpen
End Sub
End Sub
Also, will this work if the program was launched inside the active drawing?
You have to lock the document before your layertable transaction. Release the lock after you commit the transaction.
I'm wondering, have you tried my code
instead of your lesson for me?
Hi Hallex,
The SaveOpenClose in my code is just a sub. In order for me to use the "CommandFlags.Sesssion" it would have to be in the main calling code. If I put it there, other things stop working, like layertables in other subs. That's why I was asking if a main command method could launch another command method.
Also, I'm not sure of any lesson for you that I posted. I was just asking if a command method could launch another command method as I was having problems with putting the "CommandFlags.Sessions" in the main command method.
You've helped me before and I'm really greatful for all the help. No slight ever intended.
Hi, mate, please do not make an offence on me
I just didn't understand your task completely,
I've used local command name in my code
Cheers
~'J'~
