.NET
Distinguished Contributor
dlhartley
Message 1 of 9 (1,494 Views)
Save and Restore UCS
1494 Views, 8 Replies
03-08-2011 12:23 PM
I'm fairly new to this, but I'm confused looking through the vb.net developer's guide and online for information about transforming the UCS.
I'd like to:
1:  Save the user's current UCS,
2:  Change to the World UCS (that's easy)
2:  Do things
3: Set the UCS back to the user's original UCS
Is there no simple way to do this?
If not I may have to learn more about matrix operations than I really wanted to:smileysad:
David
matus.brlit
Message 2 of 9 (1,472 Views)
Re: Save and Restore UCS
03-09-2011 03:20 AM in reply to: dlhartley
UCS only affects user interaction, all your operations with entities take place in WCS
dlhartley
Message 3 of 9 (1,467 Views)
03-09-2011 06:48 AM in reply to: dlhartley
Part of what I'm doing involves extrusions, and I get unpredictable results if I don't first set the UCS to world.
In VBA this was fairly straightforward, but different in vb.net, hence the posting.
Moderator
Alexander.Rivilis
Message 4 of 9 (1,461 Views)
03-09-2011 07:25 AM in reply to: dlhartley
You can P/Invoke acedSetCurrentUCS, acedGetCurrentUCS and acedRestorePreviousUCS
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
dlhartley
Message 5 of 9 (1,445 Views)
03-09-2011 11:04 AM in reply to: dlhartley
Thanks!  That sounds like a better approach
dlhartley
Message 6 of 9 (1,419 Views)
03-10-2011 07:04 AM in reply to: dlhartley
After doing some research, part of my problem was not knowing what I was looking for.  The following code does what I need, except for one thing:
The viewport changes to the orthogonal plan view at the end of the toUser Sub.
How do I keep the user's viewport view as-is?
David
Public vect1 As Vector3d
Public vect2 As Vector3d
Public org As Point3d
 Public Sub toWorld()
            Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
            Dim acCurDb As Database = acDoc.Database
            vect1 = acCurDb.Ucsxdir
            vect2 = acCurDb.Ucsydir
            org = acCurDb.Ucsorg
            acDoc.Editor.CurrentUserCoordinateSystem = Matrix3d.Identity
        End Sub
Public Sub restoreUCS()
            Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
                '' Open the UCS table for read
                Dim acUCSTbl As UcsTable
                acUCSTbl = acTrans.GetObject(acCurDb.UcsTableId, OpenMode.ForRead)
                Dim acUCSTblRec As UcsTableRecord
                If acUCSTbl.Has("New_UCS") = False Then
                    acUCSTblRec = New UcsTableRecord()
                    acUCSTblRec.Name = "New_UCS"
                    acUCSTbl.UpgradeOpen()
                    acUCSTbl.Add(acUCSTblRec)
                    acTrans.AddNewlyCreatedDBObject(acUCSTblRec, True)
                Else
                    acUCSTblRec = acTrans.GetObject(acUCSTbl("New_UCS"), OpenMode.ForWrite)
                End If
                acUCSTblRec.Origin = org
                acUCSTblRec.XAxis = vect1
                acUCSTblRec.YAxis = vect2
                '' Open the active viewport
                Dim acVportTblRec As ViewportTableRecord
                '' Set the UCS current
                acVportTblRec.SetUcs(acUCSTblRec.ObjectId)
                acDoc.Editor.UpdateTiledViewportsFromDatabase()
                acTrans.Commit()
            End Using
End Sub
junoj
Message 7 of 9 (627 Views)
06-20-2013 08:36 AM in reply to: dlhartley
Hi David, I am trying to do the same thing you are trying to do. I would like to change the UCS then create a polyline on a new UCS (not same as WCS). But when I create a polyline it adds it using WCS. Can you please point me to the right direction.
Thank you,
Valued Mentor
jeff
Message 8 of 9 (616 Views)
06-20-2013 10:24 AM in reply to: junoj
See this article about using Editor.CurrentUserCoordinateSystem Property
http://spiderinnet1.typepad.com/blog/2012/03/autocad-net-api-ucswcs-entity-creation-and-matrix3dtran...
You can also find your answers @ TheSwamp
junoj
Message 9 of 9 (609 Views)
06-20-2013 12:57 PM in reply to: jeff
Thank you very much Jeff !!!!    :smileyhappy:
