.NET
Save and restore osnap preferences
2 REPLIES 2
davidgarner
461 Views, 2 Replies
I can't figure out how to save and/or restore osnap preferences. As well as dynamically turn snaps on and off.
I've found the osnapmasks enumeration, but I can't find any methods or properties that use these masks in the Object Browser. Am I missing something? Any hints on where I should be looking?
2 REPLIES 2
dmarcotte4
in reply to: davidgarner
look at
GetSystemVariable("OSMODE")
SetSystemVariable("OSMODE" , val)
Dan Message was edited by: Danielm
davidgarner
Perfect, that's it. I overlooked the OSMODE variable thinking it had to do with "Operating System".
Too bad you can't use the ObjectSnapMasks directly in the
SetSystemVariable() function, but instead it needs to be cast to and Int16 object.
Thanks for the direction. All is well.
Something good is going to happen to you today.
”Boost
