I tried the following method to save all drawing currently open. It always fire fill access arror, whereas AutoCAD can save the file wihthout any issue. Here I am checking for drawings that not even saved once and ask the user to take action for those files.
try
DocumentCollection docs = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager;
foreach (Document doc in docs)
string dname = doc.Name;
string s = doc.Name.Substring(doc.Name.LastIndexOf('\\') + 1);
if (s != doc.Name) //checking for additional path
doc.Database.SaveAs(dname, true, DwgVersion.Current,doc.Database.SecurityParameters);
else
System.Windows.Forms.MessageBox.Show("Please save " + doc.Name + " manualy!!!!");
catch (System.Exception ee)
System.Windows.Forms.MessageBox.Show("Exception: " + ee.Message);
Shijith
For some reason I have had some problems saving to some acad versions. Try changing this bit to see if this works:
doc.Database.SaveAs(dname, DwgVersion.AC1800)
Thanks for the reply.
I tried it, it also behaves the same.....It gives the following AutoCAD message and exception.
Autocad Message: Error writing / closing file.
Exception: efileAccessErr
But the same drawing Autocad saves with out any trouble.
Shijith
