.NET
save a DXF to DWG without opening it in the editor (AutoCAD)
2 REPLIES 2
ccalvo12
889 Views, 2 Replies
Hello:
I can save a file as DXF to DWG without opening it in the editor (AutoCAD). when a DWG file is not complicated (see the example code) but would like to be a DXF?
On the other hand in the case of opening a DWG (with no the editor) and store in a last AutoCAD, for example AutoCAD 2000 or AutoCAD 2000 DXF. What should allocate where it says "DwgVersion.".
means AC1001, AC1002 ... What belongs to whom?
Thanks for your attention
 db.ReadDwgFile(files , FileShare.ReadWrite, False, "")
 Dim fileName As String = files & ".dwg"
 db.SaveAs(fileName, DwgVersion.Current)
2 REPLIES 2
arcticad
in reply to: ccalvo12
http://autodesk.blogs.com/between_the_lines/autocad-release-history.html
(defun botsbuildbots() (botsbuildbots))
Hallex
See code by JeffH here
http://www.theswamp.org/index.php?topic=37409.msg424143#msg424143
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
”Boost
