.NET
Running exe from Autocad Menu
3 REPLIES 3
436 Views, 3 Replies
I'm wanting to run a C# exe from the AutoCad menu. Using 2008 and C# 2008 and .NET 3.5. Is this possible? If so, how? I know about the netload command, but it seems that only applies to dll's.
TIA Once Again,
John
3 REPLIES 3
jbooth
Yes, it's possible. There are several ways to go about it.
Easiest method is to write a VBA macro that calls the Shell() method. Worst case scenario you create a .NET dll that invokes your exe.
No problem.
Can you use the START command? There's also the (startapp) AutoLISP
function. 🙂
Owen Wengerd
President, ManuSoft <>
VP Americas, CADLock, Inc. <>
Thanks to both of you for replying. I got it to work using the start autolisp command that was recommended.
John
”Boost
