.NET
running a routine to 1 computer only
3 REPLIES 3
a7v1n
254 Views, 3 Replies
hi. is there any way to make a routine written in .NET run on one machine only? If its loaded on a machine, no other machine can load it at the same time. thanks!
3 REPLIES 3
elliottpd1
in reply to: a7v1n
If I was doing this, I would have the program check the System.Environment.MachineName and exit if it is not the designated computer.  You could do the same thing if it is meant for aa particular user:  check the System.Environment.UserName for the designated user.
Regards, Pete
a7v1n
in reply to: elliottpd1
this is possible only if i know the computer name or user name. i want to be able to run it in only 1 random computer. is this possible? thanks!
a7v1n
in reply to: a7v1n
what i meant is that the dll file is licensed. only 1 machine can run it. is this possible in .nET? Thanks!
”Boost
