.NET
.NET
Valued Contributor
RPeter
Message 1 of 20 (766 Views)
Run command on double click block with specific name?
766 Views, 19 Replies
02-26-2013 08:00 AM
I wrote a couple of functions one of them creates a block with a Name let say "MyBlock".
I wrote a command "MyBlockEdit" where the selected block attribute data is displayed in a custom form to change some of the properties.
Now I want to add the folowing function:
When a block with the blockname "MyBlock" is doubleclicked the command "MyBlockEdit" is triggered in place of the attribute editor.
Can someone show me the way how to apply this?
I have finally found a bit time to work out an solution to the issue you have (or rather, the issue my posted solution has): Editor.SelectImplied() does not select a blockreference that has attributes. I would consider a bug.
My workaround is to drop using Editor.SelectImplied() in the Application_BeginDoubleClick event handler. I published a new article in my blog on the updated solution here:
http://drive-cad-with-code.blogspot.ca/2013/03/update-custom-double-click-action-using.html
norman.yuan
Message 2 of 20 (740 Views)
Re: Run command on double click block with specific name?
02-26-2013 10:08 AM in reply to: RPeter
This has been discussed recently and Balaji Remamoorthy has posted a solution:
http://forums.autodesk.com/t5/NET/How-to-capture-double-click-event-in-AutoCAD-using-VB-NET/td-p/371...
http://adndevblog.typepad.com/autocad/2012/12/customizing-double-click-on-block-reference.html
I also posted a solution in my blog, in which user do not have to modify DoubleClick action in CUI. see it here:
http://drive-cad-with-code.blogspot.ca/2012/12/custom-double-click-action-using.html
HTH.
Valued Contributor
RPeter
Message 3 of 20 (704 Views)
02-27-2013 10:54 PM in reply to: norman.yuan
Norman, thanks to you I established to trigger the doubleclick command. However I'm strugling with the select.implied.
I've added temprorary a editor msg with the count of the selected objects. When I use select.implied it always return 0.
In my other command MyBlockEdit I also use the select.implied, this however doesn't seem to give any problem.
I think (not sure of it) that when I double click the selection gets lost and there is nothing selected anymore.?
norman.yuan
Message 4 of 20 (694 Views)
02-28-2013 06:43 AM in reply to: RPeter
Are you saying that in the Application.BeginDoubleClick event handler, the Editor.SelectImplied() always return 0 count of selected?
When you double-click on an entity, does it get highlighted? Or is the pickbox (cursor) too small and no entity is actually selected when you double-click?
Could you show your code in the event handler?
Valued Contributor
RPeter
Message 5 of 20 (689 Views)
02-28-2013 07:50 AM in reply to: norman.yuan
Norman,
I'm out of office right now so can't copy the exact code, will do this first thing tomorrow.
The code looks like this:
Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
ed.WriteMessage(vbCrLf & "Custom Double-Click action started.")
Dim res As PromptSelectionResult = ed.SelectImplied
If res.Status = PromptStatus.OK Then
    ed.WriteMessage(vbCrLf & res.Value.Count & " object(s) selected.")
    'some more code to check if the selection is the right Dynamic Block...
End If
I get the message that the double-click action is started.
The return of the selected object count is always 0.
ed.selectprevious or ed.selectlast returns 1 (or more) but is never the correct selected entity...
Moderator
Alexander.Rivilis
Message 6 of 20 (682 Views)
02-28-2013 09:56 AM in reply to: RPeter
If your's code is a command it must have CommandFlags.UsePickSet attribute in order to use ed.SelectImplied
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Valued Contributor
RPeter
Message 7 of 20 (669 Views)
02-28-2013 10:16 PM in reply to: Alexander.Rivilis
Alexander,
It's not a command, its a Double-Click handler.
Norman,
Here is the code from my app:
Public Shared Sub MyDblClick(ByVal sender As Object, ByVal e As BeginDoubleClickEventArgs)
    End If
End Sub
 I've tested some more with the code from above:
Double-Clicking on a Polyine, Rectangle,... it will return the number of the selected items.
Double-Clicking on a block (without attributes) = result of selected items.
Double-Clicking on a block (with attributes) = no result of the selected items.
How can I pass this problem?
Moderator
Alexander.Rivilis
Message 8 of 20 (661 Views)
02-28-2013 10:56 PM in reply to: RPeter
RPeter wrote:
Alexander,
It is look like a bug. But I think there is workaround: using PointMonitor event to monitor entity under cursor in moment of doubleclick.
norman.yuan
Message 9 of 20 (650 Views)
03-01-2013 07:15 AM in reply to: RPeter
OK, I verified with this code:
private void Application_BeginDoubleClick(object sender, BeginDoubleClickEventArgs e)
            Document dwg = Application.DocumentManager.MdiActiveDocument;
            Editor ed = dwg.Editor;
            PromptSelectionResult res = ed.SelectImplied();
            if (res.Status == PromptStatus.OK)
                ed.WriteMessage("{0} entit{1} selected.", res.Value.Count, res.Value.Count > 1 ? "ies" : "y");
            else
                ed.WriteMessage("\nCannot select implied selection set.");
The Editor.SelectImplied() work with line, circle, arc, block WITHOUT attribute (e.g) PromptSelectionResult.Status returns OK). However, if we double-click a block that has attribute, the returned status is PromptStatus.Error. So, I am not sure if it is by design (probably not, because the built-in doubleclick action defined by the CUI works). It could be a bug as Alexander suggested. If so, it is serious blow to my double-click solution, because calling up custom dialog box on double-click would likely be used more often on editing block with attribute. I'll have to find workaround and updte my blog post.
I currently only have access to Acad2012, and hope this has already been fixed in Acad 2013, or upcoming Acad2014?
Valued Contributor
RPeter
Message 10 of 20 (640 Views)
03-01-2013 10:32 PM in reply to: norman.yuan
Norman,
The problem is still there in 2013 (+SP1), this is the version we use about 3 months now.
We have no plans to upgrade straight away to the 2014 when its available becouse where are in a Vault implementation process right now for all our Autodesk Software.
I'll try to search for a work arround, if I would find a solution I'll post it here.
