.NET
run a command at the VB.NET
4 REPLIES 4
Brunogaiola
285 Views, 4 Replies
Hello, I need that when you click the Finish button to my project in VB to execute one line at AutoCAD.
do not know the syntax, can someone help me?
4 REPLIES 4
Hallex
in reply to: Brunogaiola
You can use this class:
http://www.caddzone.com/DBUtils.cs
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Hallex
Code converter if you ned
http://converter.telerik.com/
~'J'~
Brunogaiola
I think not quite ...
I run a line at the cad when finished
VB
I need to use the AcadAppication?
for example:
run in unloadme ( "c: mate2")
this command must be executed when the cad
Finally VB
Hallex
Sorry, no ideas at all
~'J'~
”Boost
