.NET
RTEXT - With Autodesk.AutoCAD.Interop.Common
0 REPLIES 0
Message 1 of 1
Martin60
484 Views, 0 Replies
Using AutoCAD 2010 I get the error "The specified module could not be found. (Exception from HRESULT: 0x8007007E)"
only on 64 bit computer.
On line
Dim BlockEnt As AcadEntity = BlockObject.Item(i)
This method chosen as function is looking for ProSteel objects within block definition.
When looping through block using
Dim BlkObj As Entity = objID.GetObject(OpenMode.ForRead)
BlkObj.GetType is ImpEntity
Am I doing something wrong or is RTEXT not supported on this platform?
0 REPLIES 0
”Boost
