.NET
rotateddimension bug in 2006
4 REPLIES 4
netcai
332 Views, 4 Replies
I use c# 2005 beta2 and to develop autocad 2006, I want to get a rotateddimension, but when I create a rotateddimension in 2006 , I got a aligneddimension. and the rotation property of roteddimension can't be set and read, it will cause a fatal error.
4 REPLIES 4
in reply to: netcai
Can you please post some code that shows the problem? Thanks,
Albert
wrote in message news:4854215@discussion.autodesk.com...
netcai
in reply to: netcai
thanks albert ,
my code is :
RotatedDimension rd = new RotatedDimension();
rd.XLine1Point = startPoint;
rd.XLine2Point = endPoint;
rd.DimLinePoint = locPoint;
//rd.Rotation = rotation; // this line will cause fatal error
ObjectId id = Tools.AddEntity(rd);
addentity is a function of my tools class
public static ObjectId AddEntity(Entity ent)
try
using (Transaction trans = Tm.StartTransaction())
BlockTable bt = (BlockTable)Tm.GetObject(Db.BlockTableId, OpenMode.ForWrite, false);
BlockTableRecord btr = BlockTableRecord)Tm.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite, false);
btr.AppendEntity(ent);
Tm.AddNewlyCreatedDBObject(ent, true);
trans.Commit();
return ent.ObjectId;
catch (System.Exception e)
throw e;
in reply to: netcai
I see. The default constructor is broken. Use the other constructor like
this:
RotatedDimension rd = new RotatedDimension(1.2,new Point3d(0,0,0),new
Point3d(1,0,0),new Point3d(1,1,1),"some text",ObjectId.Null);
Sorry about the inconvenience. I see to it that we fix this for the next
release.
albert
wrote in message news:4855391@discussion.autodesk.com...
thanks albert ,
my code is :
error
try
BlockTable bt =
trans.Commit();
throw e;
netcai
in reply to: netcai
thanks.
”Boost
